Artist Control not working at all
I own an Artist Control and I have been using it successfully for about 6 years. Yesterday my Avid Artist Control died. It lost all power, does not start up, no lights, zero it is 100% dead. I took it for repair (I have extended guarantee from the dealer) and they confirmed that power supply is good and that the unit is in fact faulty/dead. They will be sending my unit to Avid to be fixed. In the mean time, they loaned me another Artist Control, however, this loaner does not work. The loaner unit does power up, as it should, but for some reason it is not connecting correctly to my system. This is what happens:
Plug in Artist Control unit and power on (unit powers on correctly). Launch Eucon 3.2 (Eucon launches correctly) Open Eucon Settings (MC Control shows *available*) Click on "add" button.....takes about 30 seconds Error message says: Network error, can not communicate, problem possible bad cable, unit not on, unit connected to another system, may be a firmware update or hardware problem. Check cables, power down unit, wait 30 seconds, and try again. (I tried re-booting everything and nothing helps) The unit is connected to the exact same network as my previous unit, nothing has changed. Thinking that it may be a firmware upgrade required, I reverted my Eucon to version 2.6 which cam in the DVD software with the loaner unit, but that did not help. Does anybody know how to fix this? Thank you G |
Re: Artist Control not working at all
Maybe the loaner is configured to operate on a static IP, and you should change it to DHCP.
Thanks, I did check my setting on my sys pref/network and I am in fact DHCP. Is there somewhere else in the actual unit that I can change this?
Solved, thank you for your help (static IP issue at the controler)
Artist Control not working with PT 11.3.2 | mars100 | Artist Series | 2 | 06-04-2016 04:28 AM |
Artist Control's Transport and Faders not working with FCP | c3kings | Artist Series | 2 | 01-20-2015 10:37 AM |
Artist Control not working with Eucon 3 on OS X 10.8.4 | Jerry Woolsey | Artist Series | 1 | 06-24-2013 01:21 AM |
PT10 LE + Artist Control and Mix via HUI (Not Working) | Herbieoz | Artist Series | 5 | 08-10-2012 07:50 PM |
When Artist control is hooked up the network stops working! | diamondschwin | Artist Series | 1 | 01-11-2012 01:40 PM |
