Go Back   Avid Pro Audio Community > Pro Tools Software > Avid Cloud Collaboration
  #21
Old 03-22-2016, 09:54 AM
tnipe tnipe is offline
Default Re: Cloud Collaboration cost
500MB is not enough for one project, let alone 3. Looks like a really obvious way to make you get an extra plan or not use this at all. Should at least be 1 GB for already paying subscribers.
  #22
Old 03-22-2016, 12:02 PM
taylor4814 taylor4814 is offline
Default Re: Pro Tools 12.5 preview
Originally Posted by dr_daw View Post
Let the groaning begin....I'll start by saying I'll be sticking with Dropbox until they rethink their archaic pricing scheme.
Curious, re: Dropbox, do you work on sessions where the whole session folder itself lives in a local, Dropbox-synchronized folder, and updates/synchronizes with Dropbox cloud as you (and others) work... will Pro Tools run in that scenario?
  #23
Old 03-22-2016, 03:26 PM
nigelpry's Avatar
nigelpry nigelpry is offline
Originally Posted by Carl Kolchak View Post
The measly 500MB of free storage - I can completely understand, at least at this point in proceedings.
What I find utterly baffling though, is that even the premium plan is limited to only two additional collaborators (three users in total) per project.
I really hope that simply means two active collaborators at any one time.
In other words, a single project could have hundreds of collaborators passing through in total, but only two additional collaborators could be actively participating at any one time.
If it is limited to two in total, Avid have seriously hobbled themselves - and even if it simply means two active collaborators, that's scuppered any meaningful adoption of the service in the Film Post world.
Of course, PT12.5 is basically the public Beta of Cloud Collaboration, so we can expect major improvements (in terms of the number of collaborators, amount of free storage, and the development of the Artist Community) by the time we need to renew our support plans.
I read it differently first time ....
I thought that the free pack gets you two collaborators, while the premium pack gets you two ADDITIONAL collaborators ..... i.e. 4 collaborators in total. But going back and re-reading it, I see even the free pack uses the word 'additional', so it seems the premium packs don't get you any extra collaborators.
It also says 'per project', so each project can have two completely different collaborators.
When comparing it to Steinberg's version of cloud collaboration, this is obviously Avid's way of limiting data transfer, whereas Steinbrg doesn't limit the number of collaborators, but charges for data transfer once you've used your free allocation.
Personally, I prefer the flexibility of Steinberg's offering, but, in reality, I don't see myself using either company's facility all that much.
In fact, though, it is more likely I'll use Avid's, as the one scenario I can see is allowing my assistant to get started with initial editing work while I'm still tracking. In that case, data transfer throughput could be much higher, which new takes passing back and forth, and the main issue will be to comp and render edits efficiently to keep within data storage limits.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10
iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6
Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors.
Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
  #24
Old 03-22-2016, 05:35 PM
dr_daw's Avatar
dr_daw dr_daw is offline
No, how I work in Dropbox is in two scenario's. One I'm the mixing engineer, and the client records in a different DAW; so they upload truncated tracks into the Dropbox and then I load them into ProTools to mix. In this scenario, Collab is with PT is not relevant.
The second is I'm the recording engineer and someone else is mixing it. In the past, if they ran pro tools and had the same plugins, I would load the session with the files up. Generally, that's not the case, so as I complete tracking, I upload truncated tracks to the Dropbox for the mix engineer to load in their DAW of choice.
For those of you wondering, what's truncated?, it means all tracks start at the same Bar. That way whoever gets it can just load it in and have it line up. You have no idea how often I get tracks that are not like this.
It may not be as fast, but it's faster than the additional cost of going from 500mb free to 20g/month. Sometimes sessions take over a year! That's a huge expense, that I'm not carrying, that's billable. Clients won't like that! :P
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
  #25
Old 03-22-2016, 09:16 PM
Very cool, thanks, was wondering about that!
  #26
Old 03-23-2016, 12:15 PM
Tom Graham's Avatar
Tom Graham Tom Graham is offline
Hi Guys,
Info posted here on the plans and pricing and how the lossless compression can make the 500MB free plan work as a starting point.
http://www.avidblogs.com/get-started...for-pro-tools/
We are working hard to make sure that everyone's experience with collab and the servers is a great one, so for now the limit of 2 collaborators and this set of offerings is where we feel we can ensure the best overall experience.
You can also see the videos that were part of the recent webinar.
Thanks much,
Tom
Tom Graham
Avid Audio Marketing
Pro Audio and Mixing
[email protected]
Check out our Pro Mixing Webinars :
http://www.avid.com/US/resources/pro-mixing-webinars
Avid Pro Mixing Blog:
http://www.avidblogs.com/promixing/
  #27
Old 03-24-2016, 11:49 AM
nigelpry's Avatar
Well Tom, credit where credit's due .... The cloud collab functionality as shown in the blog videos is very impressive.
While I don't think I'll be a big user of it, I can certainly see that Avid has put a lot of thought into how to make this a genuinely viable workflow for people that need it. I can see one element of my workflow where this could be very useful, i.e. to allow an assistant to work on edits and comping while I continue tracking.
My main concern is what the effect of this major new feature set might be on the general stability of PT, especially as many of us continue to encounter a less than robust product as it is. And, of course, what impact correcting any issues with this new flagship functionality might have on the timsescales for fixing outstanding issues with the current (pre collab) feature set.
Nevertheless though, well done so far for coming up with a collab feature set that actually seems well thought out.
One question that does come to mind, given that we are limited to two additional collaborators .... Will it be possible, once a collaborator has competed his/her work, to 'delist' that collaborator, thereby opening up a slot for another collaborator to be added?
  #28
Old 03-24-2016, 05:11 PM
Tom Graham's Avatar
Thanks Nigel… I hope you get a chance to check out 12.5 in action when it ships. I have to say - the using it is a lot of fun and manages all the complex tweaks people like to do (after they've sent you something)!
Some might not know, but a trick to keep another version of Pro Tools side by side on Mac is to change the name of the app to say 'Pro Tools 12.4' and then 12.5 will install in addition to the old version. That way if you are concerned about stability - you can easily run either one without rebooting.
So yes - you can 'delist' a current collaborator and then invite a new one. And or - a person can leave as a collaborator on their own.
Tom Graham
[email protected]
  #29
Old 03-24-2016, 05:12 PM
Tom Graham's Avatar
PS - no ones made any jokes about my song yet…
Tom Graham
[email protected]
  #30
Old 03-24-2016, 06:07 PM
YYR123's Avatar
YYR123 YYR123 is offline
That would be mean wouldn't it?
Honestly I haven't seen it, but I am in the camp with Sir Nigel....glad you got it to work and wish you well but I am not planning on using the features
I have a setup in the country, and bank on people coming to me... :)
BTW - When are you gonna sell me your used D-Command ?
Cheers
Daniel
Avid Everywhere / PT Cloud Collaboration peter5992 General Discussion 1 03-16-2016 08:26 AM
Cloud Collaboration hacha Foro en Español 9 07-07-2015 08:53 AM
Yes to cloud collaboration! reichman Avid Cloud Collaboration 91 06-17-2015 09:07 AM
Cloud collaboration vs real collaboration midnightrambler Pro Tools 12 13 06-11-2015 01:48 PM
Cloud Collaboration Cost? SearingSounds Pro Tools 12 3 01-28-2015 08:38 PM
