Old 11-08-2010, 08:06 AM
Hanswurstlsepp Hanswurstlsepp is offline
Default VEP cannot connect to server in one PT-session
I'm just wondering if anyone has ever got s.th. similar ?
In the session I'm working on (some VIs - bout 20 Structures, 1xBattery, 2xXpand) VEP plugin won't see none of the 2 running server instances. So there's no way to use VEP within that session.
I already imported all tracks from that session into a new blank session without success.
And yes ... I deleted PT-prefs and repaired disc permissions...I even installed VEP new - all helped nothing.
One VEP64bit server is running on same MacPro as PT does and another VEP32bit server is running on MacBookPro.
At every other session I tried, VEP works fine.
I have never had this problem before. Anyone else ?
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
500 Internal Server Error We're sorry but the web server encountered an unexpected c DrumEatDrum Getting Started 10 07-09-2013 11:47 AM
Files transfered server-server relay still downloaded from remote server Phill Barrett Aspera DigiDelivery 1 03-19-2010 01:58 AM
Problem with connect W2k Server KMK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-05-2007 10:23 AM
Pro Tools Source Connect VO Session in LA minister Post - Surround - Video 10 02-22-2007 08:25 AM
Server-to-server relay questions! StefanLindstedt Aspera DigiDelivery 4 09-07-2005 11:17 AM
