Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 11-02-2010, 01:54 PM
disinfor disinfor is offline
Default Import Session Data with out Audio import
I don't think it's possible, but if someone can confirm for me, that would be awesome (and crappy at the same time :)
Is it not possible to just import channel strip settings and not the audio data from another session? I thought I saw you could do that in HD, but the option for not including playlists in M-powered (7.3) doesn't appear to be there.
If it's not, I'll just keep importing all of it, and deleting the audio.
Old 11-02-2010, 04:24 PM
BEN6732 BEN6732 is offline
Default Re: Import Session Data with out Audio import
Sorry man, you're out of luck. This is not possible in M-Powered... Only HD or LE with DV or Complete Toolkit
Old 11-02-2010, 06:30 PM
cdavis6406 cdavis6406 is offline
Work around is this import tracks be sure to select "link to audio" not "copy audio". Then after the tracks are imported select the audio from the regions list and clear it from the session (not delete!). Then youll have them without the audio
Mac Pro, Snow PT 10HD,Sequoia, Reaper
W7/64, PT 9HD,Sequoia, Reaper
192 HD, HD-N, 002C BLA,
BLA AGB,Autuer,Lucid,
MicroCLock, Pultec, UA, Sebatron, Focusrite, Trident,API, A-Designs, Purple Audio
Old 11-04-2010, 11:31 AM
Thanks guys, that's what I thought.
Actually, cdavis, it's probably safer to copy the audio instead of linking in the event you accidentally delete, you won't lose the original copy.
Pro Tools M-Powered 7.3
Mac OS X 10.5.7
MacBook CoreDuo
Focusrite Octopre MKII
Alesis AI-3
M-Audio Profire Lightbridge
Rock and Roll
Old 11-07-2010, 06:42 AM
Actually, disinfor, its safe to link then remove (Clear) the linked audio, as long as you clear it and not delete it. But if you choose delete instead of clear then its gone. But it does boil down to what button you click with your mouse.
Old 11-08-2010, 05:56 AM
Franco1967 Franco1967 is offline
Smile Re: Import Session Data with out Audio import
THERE IS A SOLUTION: When you save the desired session as a template (you can save the template where you want it, maybe on the desktop) and then open the new session you can import all data via session data import without the audio files or other files. Hope thet helped
Old 11-08-2010, 07:54 AM
That's one of those "Duh", moments, he's totally right about the session template. Forgot about that one myself.
Old 11-14-2010, 11:44 AM
Oh man...Franco, I hadn't thought of that...that is a "duh" moment.
Thanks!
Mac OS X 10.5.7
MacBook CoreDuo
Alesis AI-3
Rock and Roll
import session data without audio data rgalpin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-06-2010 01:49 PM
import 5.1 session data or audio Fritz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-11-2009 07:35 PM
Loosing Audio Files after import Session Data deanguidry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-10-2009 06:18 AM
Import Session Data Bug? Audio not playlisted at all SmokinBaldMonkey Pro Tools TDM Systems (Mac) 2 10-07-2008 02:55 PM
Import track color in import session data deardaddy Pro Tools TDM Systems (Mac) 5 06-11-2007 06:35 PM
