Old 07-21-2010, 08:17 PM
Masteredit68 Masteredit68 is offline
Default Can the project PT HD open on LE?
Hi. Everybody
I have a file project that made from PRo Tools HD . And i want to open with PRo tools LE . ( because i don't have Pro Tools HD) Can i do that ?
Thank you so much
Old 07-21-2010, 08:31 PM
LanceK LanceK is offline
Default Re: Can the project PT HD open on LE?
I believe you can, but any TDM plug ins won't work. Also lower track count.
Old 07-21-2010, 08:47 PM
Thank you. I will try later when i get my audio interface.
Old 07-22-2010, 12:09 AM
crizdee's Avatar
crizdee crizdee is offline
Yes it will, unless it was created with a newer version of pro tools!!
If it was created on a newer version, then on the TDM system it can be saved in "save copy as" where you can select to save it as previous version compatible.
Any matching plugins you have on LE will switch to RTAS and open ok.
Other things will need to be checked! mostly LE not having delay comp so checking the phasing on tracks will be priority.
Chris
Producer, Engineer,
www.ukmastering.com
Old 07-22-2010, 01:43 AM
Originally Posted by crizdee View Post
Chris
Thank you.. I going to use Pro Tools 8.0 LE and MBox 2 Pro
Old 07-22-2010, 02:13 AM
Avid's Avatar
Avid Avid is offline
Administrator
See "Chapter 16: File and Session Management and Compatibility" in your Pro Tools Reference Guide for more details.
Administrator
is it possible to open a project that was done on a mac on a p.c. with pro tools?? tony.tipton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 11-27-2010 10:32 AM
open 6.4 project mooneh Pro Tools M-Powered (Win) 5 05-18-2009 11:02 AM
can`t open project, please help. stolz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-16-2007 12:06 PM
Can't open project jormaggio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-05-2003 02:50 PM
Open a Mac Project on a PC HOW? TallCat Pro Tools TDM Systems (Win) 2 10-06-2003 02:41 PM
