Old 09-19-2018, 03:17 PM
Mishabou Mishabou is offline
Default Loop record with pre/post roll
Hi there,
Is it possible to loop record with pre/post roll ?
Let say I want to loop record at beginning of bar 3 til the end on bar 4 with a pre/post roll of one bar, therefore play back starts at bar 2 and will loop around when it reaches the end of bar 5.
Old 09-19-2018, 09:17 PM
EdwardWilliam's Avatar
EdwardWilliam EdwardWilliam is offline
Default Re: Loop record with pre/post roll
Post roll won’t work with loop rec because loop record repeats until you manually stop recording/playback. Pre roll, if I recall correctly, only occurs before the first loop, but subsequent loops follow the selection. So, make sure your selection has the extra time you need before and after the section you’re tracking.
Edward
PT8/7 Pre/Post roll in loop record mode question - is there a bug or is it normal? bukman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-07-2011 06:07 AM
Loop Record/pre roll Mac88s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-25-2009 10:25 AM
Make PRE-ROLL stick in each pass in loop record mode? el matador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-23-2008 03:46 PM
Pre-Roll on loop record / need Preroll on each tak CisumBlue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-23-2005 04:25 AM
Pre/post roll in loop recording 6X 2 Pro Tools TDM Systems (Mac) 1 10-23-2001 10:44 AM
