Old 07-20-2010, 09:17 AM
jeremyroberts jeremyroberts is offline
Default Continuously Variable Track Height - crashing 8.0.1cs2 (PPC)
I don't usually use Continuously Variable Track Height in the edit window, but since migrating to VSL instruments, the need to edit multiple lanes of automation data all at once led me to start resizing the track height by simply dragging. THE PROBLEM is that I can pretty much guarantee a CRASH if I have
1. MIDI instrument track with at least one additional automation lane visible;
2. In any view (notes, region, midi volume, velocity, doesn't seem to matter) try to resize the main track "by simply clicking and dragging the lower boundary of the Track Controls column".
Crash. SPOD.
This has been happening in more than a few different session files.
Tried holding command for non-incremental sizing -- crash before it could do anything. Instant SPOD.
Anyone else ever experienced this?
I am mixing and don't feel like testing right now... but I will go back to using my trusted key commands (control-uparrow/downarrow) but I was hoping to use non-incremental track sizing. Hmmm. Bummer. The SPOD crashes suck when you're on a creative roll. This function is the only sure-way that I can crash PT 8.0.1cs2
Doctor it hurts when I do that.
So don't do that.
PTHD 8.0.1cs2
PPC mac G5 2.7, 8gb ram
hw buffer -- doesn't matter. Crashed when it was 256, crashed when it was 1024.
--Jeremy
Old 07-20-2010, 09:38 AM
Stig Eliassen's Avatar
Default Re: Continuously Variable Track Height - crashing 8.0.1cs2 (PPC)
Can you get away with Shift-Option-Command-dragging?
Old 07-20-2010, 09:43 AM
doesn't do anything... not on the edit window track vertical height.
and just because I needed to punish myself, I tried to to the vertical drag just now, and of course, it works just fine now.
I think this crash is related to my system forcing me to take breaks and slow down. I wouldn't get out of the chair if the machine always worked perfectly. right?
--Jeremy
Old 07-20-2010, 09:50 AM
It should continuously adjust track height on selected tracks only.
Old 07-20-2010, 10:06 AM
not for me. Shift-Option-Command-dragging does nothing for me in the EDIT window. I'd make a video, but I want to get back to my mix. When I need a break, I'll run video and try to crash this later. Thanks. J
--Jeremy
Old 07-20-2010, 12:13 PM
meech meech is offline
continuously variable track height has not worked for me at all since PT 8. It just snaps to default sizes and won't change size when command-clicking
Mapping the tempo of a track the changes continuously jschmidtiii macOS 1 05-11-2013 02:20 PM
Continuously writing (or tapping) tempo track in real time stevegalante macOS 3 04-22-2013 08:03 PM
continuously variable mix window track size paulreed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-02-2009 07:46 AM
Continuously Crashing On Load BakedBeans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-08-2008 10:52 AM
ProTools LE 7.3.1cs2 crashing on file rename reichman Post - Surround - Video 0 03-27-2007 06:02 PM
