Old 05-22-2017, 02:04 AM
Bulley Bulley is offline
Default PT Crash Changing sample rate
On Win 10, PT 12.7.1, Motu 16A I'm getting crashes every time I try to move between sessions at different sample rates.
Even if I close Pro Tools, then try to load session at a different sample rate, I can see the Motu clock briefly flick to whatever the sample rate of the last session loaded was.
Trashing prefs doesn't seem to help, the only work-around I can find is to create a new session at the target sample rate, close that and then open the other session.
Anyone else experience this?
Old 05-22-2017, 08:43 AM
sw rec sw rec is online now
Default Re: PT Crash Changing sample rate
Using your MOTU as the default Windows sound device?
Old 05-22-2017, 08:58 AM
For playback, no. For recording, yes as there is no other device to use.
Old 05-22-2017, 05:58 PM
What are you recording in Windows???
Your best bet is to un-designate your Pro Tools interface as a default Windows sound device.
Let Windows have the onboard sound card.
Old 05-24-2017, 08:42 AM
Prabha Prabha is offline
PT can be quite a diva when switching sample rates with some devices.
I use a SSL MX4 MADI card and also have issues when changing sample rates.
My workarround is:
Close the session in sample rate A
Switch Protools audio engine to PC integrated audio
Switch sample rate in my hardware
Switch back Protools audio engine to my hardware
Open session in sample rate B
I hope it helps!
PC i79700K 4.8Ghz 32Gb ram Nvidia1050
Win 10 64
SSL MX4
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up finalcut Windows 12 02-20-2012 04:00 AM
Changing Sample rate from 96 to 44.1 langelo68 General Discussion 4 08-29-2009 08:18 PM
Changing Sample Rate. Estudio JLS Pro Tools TDM Systems (Mac) 2 04-19-2007 03:58 PM
Changing sample rate? chino_151 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-21-2005 05:15 PM
Changing Sample Rate mushmouth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-21-2005 11:07 AM
