Old 04-01-2017, 11:08 AM
tjs5200 tjs5200 is offline
Default Stop MIDI notes from overwriting other MIDI Notes?
This may be an amateur question, but I'm not used to using midi directly in pro tools. Why is it that after laying down a sequence (lets say on an instrument track with superior drummer plugged in) if I try to say, add a hi-hat over a kick that's in place as soon as I paste the note the kick will be removed? How do I turn this off?
Old 04-01-2017, 11:30 AM
Default Re: Stop MIDI notes from overwriting other MIDI Notes?
Try enabling MIDI merge
Jack
QAPLA!
Old 04-02-2017, 09:44 AM
Marsdy Marsdy is offline
You say you are pasting? That will erase what's already there. Instead of paste use merge - (option+m)
Dave Marsden
UK
Old 05-09-2017, 10:21 PM
maddmannmuzik maddmannmuzik is offline
try creating another midi track and route it to the instrument that way your editing a different clip but still routed to the instrument. its better that way anyway just for arrangement purposes. in my opinion.
Keep a "sound" mind...
HIGH QUALITY HIP HOP INSTRUMENTALS!
Old 06-16-2017, 04:01 PM
glasswing glasswing is offline
Don't paste use the pencil and write in the notes - or use MIDI merge. MIDI merge is terrific as long as you keep track of what you're doing. I use it all the time because for some reason Pro Tools won't record the first or last notes sometimes when I define a block to record in. But that's recording live over the existing drum or whatever track.
That's what I recommend. Use MIDI merge and just record the separate drum parts in separate passes.
Hope this makes sense
Mac Studio Ultra / 128 RAM/2TB HD / Avid HDX Chassis / 2 X Sonnet Echo Dual NVMe Thunderbolt Docks w Samsung 970 EVO Plus (6TB) / Avid C24 / Avid 16X16 I/O Analog / Lynx Aurora 16/16 1/O Analog / Dangerous 2 Bus / Benchmark ADC1
www.glasswing.com
www.richardsales.com
MIDI notes continue sounding even after stop the record marcos_musika Pro Tools 12 7 02-21-2016 07:04 AM
Not overwriting MIDI notes when using CC grateful macOS 2 06-11-2013 03:57 PM
Recording Midi notes and keeping existing notes during record Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2008 09:40 AM
Why are midi notes so small in notes view Gothboy MIDI 1 05-27-2008 06:17 AM
MIdi - All Notes Off at stop The Drummer Pro Tools TDM Systems (Mac) 5 08-02-2005 01:44 PM
