Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 10-24-2016, 03:17 AM
qtvaudio qtvaudio is offline
Default DSP Pilot App hanging
Hi
Anyone have any tips as to why my DF66 DSP core is failing to find its network and connect to the rest of the system? DSP Pilot is not connecting to the network at all; Ive had it working before! Argh
Old 10-24-2016, 05:48 AM
Rpro Rpro is offline
Default Re: DSP Pilot App hanging
Is your DF66 IP configuration set for DHCP or static? Check the IP settings on your SC263/264 and make sure the DF66 is on the same subnet.
Windows Pro 10 X64 - Pro Tools 12.8HDX
Windows Pro 10 X64 - Nuendo 10
Windows Pro 10 X64 - Cubase Pro 10
Euphonix System 5, 408's, 401, 402, 403
eMix 6.1.1.20.1, HybridAPP 20.1, EuconWS 3.6.1
Old 10-24-2016, 09:45 AM
Steven1145 Steven1145 is offline
Reboot your ethernet switch and check network connection also.
sent from my Galaxy S7 Edge
Steven Ghouti
YELLOW CAB Studios
Paris, France
The studio FB page
Old 10-25-2016, 01:22 AM
how can i reset it from DHCP tho? this is the way the rescue disk configures it, and it's embedded Windows
Old 10-25-2016, 01:26 AM
All my s5 are static IP, it's the S5MC that uses DHCP if I remember correctly.
Steven Ghouti
YELLOW CAB Studios
Paris, France
The studio FB page
Old 12-15-2016, 09:10 AM
Fixed it:
The DSPPilotApp.ini file was not talking to the network interface in the DF66...by changing the name of the adapter in the .ini to Local Area Connection (it was previously looking for one called Euphonix) it worked
Thanks guys
Old 04-25-2017, 07:44 AM
typeit typeit is offline
Hello Qt, I have the same problem with the mixer, I have the Pilotapp message appear but I can´t change the LAN to local Aerea, like explained on the thread.
I can't access the network, the embedded system does not let me do ANYTHING, any Ideas, thank you.
TC Level Pilot w/Control 24?? Armando ProControl, Control|24, Command|8 2 06-29-2015 10:04 AM
FS: TC Electronic Level Pilot crandallwarren Buy & Sell 1 06-30-2014 06:10 PM
7.2 MIDI Bug? Suck? or Pilot Error? RobMacki Pro Tools TDM Systems (Mac) 3 11-29-2006 08:00 AM
7.2 AudioSuite Bug, settings, pilot error? RobMacki Pro Tools TDM Systems (Mac) 0 11-03-2006 04:51 PM
plug in count for palm pilot coaster General Discussion 19 02-16-2001 01:55 AM
