Old 01-28-2015, 06:42 PM
Irvgold01 Irvgold01 is offline
Default M-Track Plus won't Playback
Hi, just getting set up. I ahve a M-Track Plus; ProTools 11. Itunes will playback through the interface, but protools won't.
Any Ideas?
Old 01-28-2015, 11:58 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: M-Track Plus won't Playback
Any Ideas?
You have to assign the m-track as the audio device to use in pro tools....
Setup > playback engine. There you should see the m-track in the selection box for the audio device to be used. You must also have the m-track's latest driver installed.
Once you've assigned the m-track it will reboot PT and should then work.
You will also need to look at the hardware settings in pro tools to assign which inputs and outputs are to be used in the m-track and whether digital or analogue etc.
Also the I/O setup page in pro tools to arrange and name your ins and outs and busses etc.
A bit of manual reading to do! But should have audio now
Chris
Producer, Engineer,
www.ukmastering.com
Track playback way too fast... cteague 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-04-2010 08:07 AM
Track Non-Playback Issue noiseboy55 Pro Tools TDM Systems (Mac) 1 11-26-2007 03:39 PM
no playback on new instrument track GOT IT NOW TA! crizdee Pro Tools TDM Systems (Mac) 3 11-07-2005 07:37 AM
24 track playback from iPod ! kova 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-01-2001 02:12 AM
True 64 Track Playback?! mikejavo Pro Tools TDM Systems (Mac) 2 07-03-2001 05:26 PM
