Old 07-26-2006, 05:16 AM
Gothboy's Avatar
Gothboy Gothboy is offline
Default Older RTAS softsynths
I know this is bottom dwelling a bit, but does anyone know of any available Mac based RTAS softsynths that will work with Pro Tools 6.1, not counting Reason? It needs to run on a 500mhz. dual processor with 768mgs. RAM. I'll be also using PT 6.4 as well. All of the softsynths I've seen commercially need some supercomputer to run on and it's all for PT 7. I know about Synthmaster but the Mac version won't be out until the end of this year and It'll probably have system requirements I can't match. What did everybody do back in 2000...in the old days as it were....when PT 6.1 first came out? I read an old article about Bjork using Koblo synths...that Tokyo 2.5, and using Pro Tools with it back then. I know Koblos' probably long out of buisness but there must be something? And what about OS9? There must be something aside from Reason that would appeal to all those that are still using that system?
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core
16 GB RAM
Mountain Lion 10.8.5/El Capitan 10.11
Focusrite Saffire Pro 40
Ableton Live 10/Presonus Studio 3
Old 07-29-2006, 03:53 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Older RTAS softsynths
I know you wanted RTAS instruments, but i ran loads of VST instruments with the Fxpansion wrapper version 1. its worth looking into and there are 100000's of VST to try!!
Chris
Producer, Engineer,
www.ukmastering.com
Question about an older Mac Pro and possible older versions of Pro Tools HD wolfman_rob Pro Tools TDM Systems (Mac) 13 07-21-2013 01:29 AM
RTAS RMX and other softsynths crashes eljodon Pro Tools TDM Systems (Mac) 17 07-22-2005 07:58 PM
RTAS SoftSynths darkglass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-28-2004 01:42 PM
RTAS softsynths on windows ? freakofnature 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 10-02-2002 05:33 PM
RTAS Softsynths??? who 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-22-2002 12:36 AM
