Old 12-16-2019, 10:57 AM
rmccam rmccam is offline
Default AJA Kona LHi Fan Noise
Hi Everyone,
I bought a used AJA Kona LHi for cheap but the fan on it is unreasonably loud. It's actually difficult to overstate how loud it is. AJA wants me to send it in for repair but I've read a few threads where people just disconnected the fan and used it.
I was hoping to see if anyone has some long-term experience with just disconnecting the fan on their Kona card? Is it working well without the fan?
For the cost of the repair I could basically just buy another card, so it hardly seems worth it.
Thanks in advance.
Ryan
Ryan McCambridge
Producer • Sound Designer • Mixer
Old 12-16-2019, 01:35 PM
JaimeGB JaimeGB is offline
Default Re: AJA Kona LHi Fan Noise
I took the fan from my LHi apart after reading some posts here and so far so good. Card Temperature stays between 82 grad celsius and 92-93. No hiccups.
No more winning noise!
It would be cool if Aja makes just a playback card without fans like black magic does.
Cheers,
Jaime
Old 12-17-2019, 05:35 AM
Thanks Jaime. That's helpful. I can't imagine that what we do is all that intensive, really.
Ryan
Ryan McCambridge
Old 12-17-2019, 05:38 AM
Hey Jaime, one other thing: Did you completely remove the fan or just cut/de-solder the power leads? I read a thread about removing the fan (that's glued on), but I'm not really seeing the point in removing it at all when you can just cut the power. Unless I'm missing something?
Thanks again.
Ryan
Ryan McCambridge
Old 12-17-2019, 08:12 AM
Thanks again.
Ryan
Hi Ryan,
I did remove the fan. This way can the heat from the chip better dissipate. After removing it you can easily clean the thermal paste. There are plenty of tutorials online. You could also leave the bottom metal part of the fan on the chip as heatsink. but I'm not sure how well that would work as it is just a flat part.
Best,
Jaime
Old 12-17-2019, 08:21 AM
Fair point! Thanks Jamie.
Ryan
Ryan McCambridge
Old 12-17-2019, 10:43 AM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
I have read somewhere that Aja honours replacements as this is a known defect on these units. Might be worth a try.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 12-17-2019, 12:30 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
I probably was the first person who took the risk and removed the fan from my Aja Lhi card. After 7 years using it without a fan and having zero issues, I recommend doing so for those who has a problem with it's noise.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 12-18-2019, 05:53 AM
Thanks everyone.
When I called AJA and pressed them about getting a replacement they said that it would have to go into service at their regular repair rates, so I guess they don't honour that anymore. Unfortunately.
That said, I had sort of figured that I'd end up having to remove the fan. I don't have a machine room so it makes more sense for me. Besides, I got the card for about $100, so paying to ship it to/from AJA and then pay for the repair is probably more expensive than the cost of another card, so it likely doesn't make sense.
Well, I guess I'll bust out the soldering iron. Thanks again!
Ryan
Ryan McCambridge
Old 12-19-2019, 10:35 AM
jeremiahmoore jeremiahmoore is offline
I've been running mine for about five years with no fan; no issues.
In a mac pro 5,1 silver tower, so ventilation is pretty decent.
-jeremiah
HTML code is On
video out: aja kona or BM decklink nucelar Post - Surround - Video 8 12-25-2017 02:36 PM
Aja Kona LHe? kkfaudio Post - Surround - Video 1 04-09-2016 07:12 PM
AJA Kona IO XT supported with PT 10.3.6 ?? vudoo Pro Tools 10 1 07-23-2013 09:46 PM
anyone tried PT 8 HD and Kona LS vudoo Post - Surround - Video 0 02-10-2009 11:25 AM
PT HD, FCP, and AJA/Kona Chris Erlon Post - Surround - Video 2 05-17-2005 10:02 AM
