Protools Midi latency
I'm using Protools 12.5 HDX . Recording the Audio-Output of a Keyboard and simultaneous the Midioutput causes a drift of the two signals from 23ms. The Midisignal is delayed by 23ms. I tried all configuration (Delay Comp. off, delay for external devices on/off, differnet playbackbuffers......)
Re: Protools Midilatency
MIDI isn't compensated, so record that first and on another pass record the audio produced by your midi box
Macpro late 2013
OS 10.10.5 unitor and Amt Midiinterfaces |
Any compression or limiting on the Master fader?
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
no plugins used
MIDI recorded latency after playing with no latency | genebackmusic | Pro Tools 12 | 8 | 01-19-2016 02:36 PM |
Midi latency when changing midi clip to other channel | marcosdipaolo | Pro Tools 10 | 0 | 10-26-2014 08:52 PM |
Virtual MIDI cable latency, Drumagog MIDI out | mesaone | General Discussion | 4 | 04-16-2014 10:56 AM |
is there latency using midi time code or midi clock(im new) | Cali Hendrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-13-2003 04:50 PM |
Protools = bad midi? Mbox latency bad? Huh? | nan_wpg_mb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-29-2002 08:23 PM |
