Old 12-07-2010, 09:29 PM
yarrick19 yarrick19 is offline
Default CPU (RTAS) Meter
When looking at the CPU (RTAS) meter I'm seeing a solid section of bars followed by blank space and then another single bar farther out (kinda like the picture I've drawn below). The number listed to the right of the graph seems to coorespond with the end point of the solid bars.
CPU (RTAS) [||||||||_______|______________ ] 25%
What is the single bar after the blank space telling me? Does that indicate some sort of CPU spike/peak? I noticed that I tend to see this with certain plugs, such as TL Space, at lower buffer settings.
In fact, if that single bar gets near the end of the graph I start to get distortion during playback in my sessions - even if the number listed to the right of the graph only says 45%. This is a little odd, as I've never experienced this in earlier versions of PT. In PT7 and 8, if too much CPU was being used it would just throw up an error but never heard any distortion. Of course, increasing the number of host CPUs or increasing the buffer size reduces the CPU usage and the distortion disappears. Has anyone else experienced this?
Old 12-08-2010, 11:37 AM
Default Re: CPU (RTAS) Meter
bump
Old 12-08-2010, 11:51 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default
Yes its spikes.. TL Space is known for that.. Not much u can do except what ur doin... thatz probly why u got no answer out of 91 view & had to bump
Sent from EPIC 4G using Tapatalk On'eim...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 12-08-2010, 01:57 PM
Right - I knew TL Space was a CPU hog. Are others experiencing the playback distortion I mentioned in the scenario above?
Old 12-08-2010, 02:21 PM
Bob L's Avatar
Bob L Bob L is online now
Do you have "Ignore RTAS errors during playback " enabled in prefs?
Old 12-08-2010, 02:23 PM
mykhal c's Avatar
mykhal c mykhal c is offline
yes, your scenario is not uncommon. my own testin' has yielded very similar results. seems as tho they rewrote part of the error messaging or at least changed the values for kickin' out the errors. so yes denormalization will definitely show itself, in some cases, before an error. FWIW i have reported this as a bug to Avid
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
[IMG] code is Off
CPU (RTAS) meter bouncing around rhumphries Post - Surround - Video 2 10-07-2010 12:37 PM
RTAS CPU meter reading 107% one processor selected! crizdee Pro Tools TDM Systems (Mac) 22 11-12-2009 10:04 AM
-9128 error with 45% RTAS meter rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 02-26-2009 03:54 PM
RTAS Meter Creeping up when stopped BrownMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-14-2008 09:32 AM
BF Free plugins, RTAS only Meter Bridge????? McMasters Pro Tools TDM Systems (Mac) 4 03-02-2004 02:17 PM
