Old 08-26-2020, 07:36 PM
take77 take77 is online now
Default Is this task possible in Pro Tools?
Say I have edited a long recording of guitar practice cutting/deleting any unwanted regions.
I now have only the parts I want to keep with varying gaps between each leftover region.
Is there a way to consolidate all the clips so that there is a specified distance/time consistently between each clip? Say 1 bars or 1 second of space between each clip?
Thanks
Old 08-27-2020, 04:24 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Default Re: Is this task possible in Pro Tools?
Unfortunately no this is not possible.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 08-27-2020, 08:52 PM
OK Thanks for the reply. I didn't think so.
I have a better idea.
I'll just export all the remaining files as individual clips.
That way they can serve as guitar loops for practice.
A riff library.
Note: I realize the "export as files" function will export only the recorded DI signal. Which is what I want since I like to re-amp and work with different sounds.
Thanks again.
Old 09-21-2020, 09:18 AM
[email protected] sleshnyc@gmail.com is offline
You can use spot mode and just add the space you wnt to the end of the previous clip.
or create a blank file of the length of the space you want and use shuffle do put them all together.
Old 09-21-2020, 09:23 PM
Cool. Thank you for the tips sleshnyc.
Pro Tools First installed, but just minimizes to task bar,.. unusable Gyrobob Pro Tools | Intro Discussion 4 08-30-2018 08:02 PM
Pro Tools screen cutting off task bar Trin382 Pro Tools 2018 7 03-31-2018 12:34 PM
I Wish Pro Tools had a task queue aasteveo Pro Tools 9 3 07-05-2011 10:54 PM
Pro tools shows up in task manager but does not boot willl3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-20-2009 08:00 AM
Pro Tools quits mid-task... i think i've done everything! alexwoodard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-07-2008 10:59 AM
