Behringer FCB1010 with Eleven Rack
I am using the Behringer FCB1010 Stock (No Special PROM)
It works great but you have to do your programming on the Foot Controller. I am in Bank Mode so I can have a Bank with 10 Presets, this is the way I prefer as opposed to Stomp Box Mode (I think it can do that too) For Midi Patch A1 is 1, B1 is 5, etc... I have them listed in this Spreadsheet I made. http://www.intecautomated.com/blindi...yBankv2_01.xls The Biggest Two Procedures: Preset Mapping - Which Program comes up when you press button. You have to Select the Bank with the Bank Up Down and then Select a Preset 1-10 (It should be lit up) 1) Press and Hold Down Button (2.5 sec) 2) Press Up to Confirm 3) Press 1 Button (Always 1, you selected the preset prior to Holding down) 4) Press Up to Confirm 5) Enter Patch to Recall (M4 would be 52, press 5 then 2) 6) Press Up to Confirm 7) Press and Hold Down Button to Save (2.5 sec) Footpedal Mapping - Continuous Control of Parameters You have to Select the Bank with the Bank Up Down and then Select a Preset 1-10 (It should be lit up) 1) Press and Hold Down Button (2.5 sec) 2) Press Up to Confirm 3) Press 8 or 9 Button (8 is Left Pedal) 4) Press Up to Confirm 5) Enter CC Number (11 is MultiFX, 4 Wah, Volume 7) 6) Press Up to Confirm 7) Enter Minimum (0-127, 0 is OFF and 127 Full Volume) 8) Enter Maximum (0-127, 0 is OFF and 127 Full Volume) 9) Press and Hold Down Button to Save (2.5 sec) You can also send a Toggle upon loading each preset. For instance I setup a Tuner Patch on Bank 5 preset 5 1) Press and Hold Down Button (2.5 sec) 2) Press Up to Confirm 3) Press 6 Button 4) Press Up to Confirm 5) Enter CC to send (Tuner is 69, press 6 then 9) (0 to turn off) 6) Press Up to Confirm 7) Enter Minimum (0) 8) Enter Maximum (127) 9) Press and Hold Down Button to Save (2.5 sec) |
Re: Behringer FCB1010 with Eleven Rack
Oh Yeah... Does anyone know if it is possible to Run ProTools without the Eleven Rack plugged in???
It is kind of Stupid that I cannot listen to Something I recorded unless I have my Eleven Rack plugged in... |
if your computer onboard audio is enabled you could use that instead of the 11r
pro-tools-pc.com TRASHER Pro Tools Utility(updated 3-6-18) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Short answer, no you can't. Pro Tools has always been very restrictive, obsessed about piracy (Logic is not), and therefore always requires a "dongle" of some sort attached, or it will not even start up. In the case of Pro Tools LE versions, the hardware that it came with is the "dongle" (MBox, Digi00x, or in your case, the 11R), and in the case of full versions, an iLok is needed.
http://www.eurekasound.com/eurekaprom/configurations/11
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Someone told me the other day that prior to PT 9, even full versions of PT required a piece of Avid hardware attached to startup. I can't comment on that - though I've worked on many PT systems over the years, I've only OWNED LE systems up until PT 9 and 10... |
with the introduction of 9 though, they did away with "LE" and went to pro tools pro tools hd pro tools mp (m powered m audio products) pro tools se (also for m audio products) the first 2 authorize w ilok and can work with any core audio or asio compliant device. the last 2 will only work on selected m audio hardware.
But thats only if you have Pro Tools 9 or 10. Quote:
fcb1010 w/eleven rack | Rob487 | Eleven Rack | 27 | 09-09-2012 03:53 PM |
FS: Eleven Rack with FCB1010 Foot Controller | J-mo | Buy & Sell | 0 | 07-08-2012 11:27 AM |
11Prom - FCB1010 - Eleven Rack - DEMO | Benoni | Eleven Rack | 39 | 09-24-2011 08:40 PM |
Behringer FCB1010 Uno Eprom Sysex File For The Eleven Rack | Benoni | Eleven Rack | 3 | 06-04-2011 06:17 PM |
How do I use Eleven Rack with FCB1010!?! | zenabi916 | Eleven Rack | 6 | 11-22-2010 01:31 PM |
