protools export audio
hello new to the forum .. im using pt/le 7.3 and
i cannot get the export audio function to work .. i record a mix back to track and then i highlight it go to export but only midi is highlighted even though its an audio file .. what am i doing wrong >.?? thanks much.. |
Re: protools export audio
Try this. Use the Selector tool and click off the timeline. Then double click on the mixed down audio track. That should highlight only that region in the Regions Window. Then either right-click or click the Regions title bar and select "Export Regions as Files..." and set your settings and export. That should do it if I understood your post correctly.
seamus |
In the regions menu make sure "select parent in project browser" is checked.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
You need to be selecting the region. Also - where are you selecting 'export' from? The regions bin? |
i appreciate all the comments.. answer to tim gale..
i was selecting export from the file menu... maybe i should select from the regions bin .? ill try it all and adv over weekend thanks...mucho... |
Bounce to disc...
Export MIDI to Audio in ProTools? | gilorlev | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-28-2008 07:21 AM |
protools OMF export | therecordinghouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-31-2008 05:57 PM |
AUDIO EXPORT FROM FINAL CUT TO PROTOOLS | herbyherb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-06-2006 05:30 PM |
Protools AAF export | MattV | Post - Surround - Video | 8 | 08-28-2004 05:48 AM |
OMF export from ProTools 6 | philper | Post - Surround - Video | 3 | 11-21-2003 01:55 PM |
