How align pan, width and depth of two different vst sounds
Hello Community,
I am new to this amazing group. I wanted to learn something. Is there a good way to align the pan, depth and stereo width of two piano vst sounds using Pro Tools? I have a Synthogy Piano vst on one track and a TruePiano vst on another track. I want to double the sound of the piano in my mix. Since these are two different vst sounds, they were recorded under different conditions, microphone placements, and width. What Pro Tools plugs in can help me match these two vst sounds up so they can blend in as closely as possible? I know of spatial spectrum analyzers but do not know how to use that information to do the matching. Any help would be appreciated. Thanks Adam |
Re: How align pan, width and depth of two different vst sounds
Well you are about to go down the rabbit hole, mixing is a very deep subject and i recommend doing reading, vid watching and experimenting.
As for your example, i would start by turning off the effects that are on each VI(reverb and possibly delay) since they dont match. Then create an aux track with a reverb on it and send from each VI track to this Aux track. Experiment with panning the VI's and the sends as well as the send levels. Add different delays to each VI with different times to make them sit differently.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
What you are trying to do is called layering and as in most layering examples I've come across, the difference between the tracks involved is what makes this practice so amazing, mainly because every new track brings a new element to the final sound. For example, if the first track sounds powerful and well defined the second track could have in contrast a large amount of reverb, then you have the possibility of creating a hybrid tone by balancing each track's volume fader.
I can't think of an automatic tool that can match panning although the EQ matching in FabFilter Pro-Q could help if it's available in L/R or M/S, it would be a matter of experimenting, for phase I use Waves InPhase and SSL X-Phase
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
What Amagras said 100 %
Why layer different pianos or guitars or whatever else if you wanna make them sound as close to eachother as possible? Just take advantage of the fact you have two different pianos and pan them by testing until they add to eachother and then put some cool delays and saturation and maybe compress some but not much as you will kill the dynamics which are probably pretty important in this instance. We always layer many different Takes and tones to get that fat warm sound and we make use of our nice analog EQs for warmth and some other outboards for coloring and very little compression if we are mixing in pianos.
All, you have been of tremendous help. Yes, it is called layering. I will exploit the two sounds for their individual characters to add more warmth.
Good idea. Thank you again. Adam |
Getting More Width | hebro1 | Pro Tools TDM Systems (Mac) | 10 | 03-18-2012 07:10 PM |
Voc Align | brickroadstudio | macOS | 1 | 04-08-2011 07:02 PM |
Voc Align | 4times4mil | Tips & Tricks | 0 | 12-30-2006 06:47 PM |
getting depth and flat sounds | arcarsenal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-02-2003 09:10 PM |
LATENCY??!!L&R don't align!! -888/24 | [Benjamin] | Tips & Tricks | 4 | 10-20-1999 01:25 AM |
