Pro Tools 12 crashing while insterting WAVES plugin
Hello,
I'm using Pro Tools 12 on a brand new computer with a WAVES Gold bundle V11. It worked perfectly for a whole day. Now, when i try to insert a Waves plugin on a track, even on a new project, Pro Tools open a white plugin window and crash. I tried uninstall and reinstall the waves bundle, trashed the preferences, etc. I don't know what to do... Does someone here had the same issue ? |
Re: Pro Tools 12 crashing while insterting WAVES plugin
And 6 hours later, i found the solution. I'm posting here what i found, in case that could help somebody.
The plugin window was opening on an external screen... i moved the plugin window on my laptop screen... and then WAVES didn't crash my pro tools anymore... I know it's weird but that's how i solved it. |
In case you're not familiar with it, here is the place to get lots of info on how to get the best help, but also very good info on optimization, compatibility and troubleshooting:
Help Us Help You |
What a bizarre bug. I actually think it’s really worthwhile you contacting Tech Support this issue and your solution, so hopefully they can fix it.
Curiously, does the same issue happen with other plugins, because maybe it’s a PT or an OS issue?? |
Pro Tools 2018.12 crashing when loading Vienna Instruments plugin at startup | SuperKons | Pro Tools 2018 | 7 | 04-22-2019 05:02 PM |
New waves central crashing Pro Tools 11 | jf.burman | Pro Tools 11 | 6 | 12-08-2015 06:17 AM |
pro tools express and waves plugin | sub14 | Pro Tools Express on Windows | 6 | 06-15-2014 09:41 PM |
Waves 8 Crashing Pro Tools 9.0.3 | espennor | Pro Tools TDM Systems (Win) | 0 | 09-27-2011 02:28 PM |
ARC Plugin crashing in Pro Tools | mahag | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-03-2008 02:41 PM |
