old pro tools computer, new interface. what to do?
hey
i'm going to use an mbox pro 2 with an older computer of mine (long story. relocation, old sessions, blah blah). i have PT LE 8.0.4 installed on that pc, but i used to have a digi002r hooked up to it. so what should i do? reinstall pro tools 8 entirely? or is there a way to avoid that? maybe i could just replace the drivers, no? if i reinstall pro tools, will i have to reinstall all my plugins too? also, i bought the mbox pro 2 without the power supply. bad move? does the mbox 2 pro work better with the power supply? and, by the way, which version 8 is best? (is 8.0.5 a good update? better than 8.0.4?) |
Re: old pro tools computer, new interface. what to do?
You should be good to go with just installing Mbox drivers;
http://avid.custkb.com/avid/app/self...3=1450&Hilite= 8.05 has been working well for me; http://avid.custkb.com/avid/app/self...p?DocId=393651 Not sure about the power supply question.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
I think zed said it well. If you have the PT8 installer disk, you could likely stick it in the drive and open Windows with the Mbox connected. Windows should install the driver off the disk all by itself. As long as you have a 6 pin FW port in the computer, it should power up fine off the FW port.
thanks guys! i'm glad i asked for advice here it was that simple and it seems to work properly.
it probably was a bad move to buy the mbox without the power supply though.. i'll post some more questions about that in another thread. cheers |
Pro Tools 9 Computer and Interface Test Results | unclemonkey | Pro Tools 9 | 3 | 11-19-2010 11:51 AM |
my computer is not receiving my instrument from my interface | elitepmpg | Pro Tools M-Powered (Win) | 0 | 02-09-2010 06:58 PM |
Monitoring from PT interface and computer | PSimpso | General Discussion | 3 | 08-20-2009 10:08 PM |
HD digidesign MIDI interface not seen by computer | jestiferann | MIDI | 1 | 08-19-2009 09:19 PM |
2 audio interface on one computer? | charter | General Discussion | 1 | 09-08-2005 06:13 AM |
