Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 01-24-2020, 07:22 AM
gdgross's Avatar
gdgross gdgross is offline
Default change Default bounce format to interleaved
Is there a way to change the default bounce format to interleaved rather than L/R.
I always forget about this then discover in my dropbox hours later when Im away from my machine...
Geoff
www.merlotembargo.com
Old 01-24-2020, 07:47 AM
Default Re: change Default bounce format to interleaved
Mine always comes up with the last settings used.
Old 01-24-2020, 08:09 AM
JFreak's Avatar
JFreak JFreak is offline
Since PT10 I've got so used to tick the interleaved box when I create a session
Janne
Old 02-13-2020, 03:11 PM
Samba Samba is offline
Does this ensure that when bouncing, it will default to stereo interleaved?
Old 02-13-2020, 03:22 PM
DetroitT's Avatar
DetroitT DetroitT is offline
No.
This is file interleave plus output width (1 file 5.1 for example) related.
But. Yes, in general if you always use the same stereo bussing routes.
t
*** A user base bounce txt (save locations) info-save.*** (Thought not available from Avid)
(Help us Help You)<<<click here
APFS 90% 10% Audio on Both.
Pro Tools U-2020.5 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
(2k10MP 5,1 / 64-Gb)
(Sapphire RX-580 MVC-Edition-dual mini 6 pin. one spliced to add Avid mini 4 pin-hdx)
FW-CoreAudio (for poly-recording)
(SSL-HUI-MIDIoverIP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
new systems builds / upkeep / +
New builds:
12 core nMP HDX 1 Slot 5 stock HDX Mac mini 6pin to 4 pin HDX power like 5,1 mp's used)
16 core nMP rack-test station
28 just because machine
Old 03-20-2020, 03:05 AM
Mine always defaults to multiple mono regardless of whether I start a new session or continue an older one.
Is this a bug? If not a bug, what's the fix?
Old 03-20-2020, 03:32 AM
JFreak's Avatar
If your session is interleaved, then your bounce is also interleaved
Janne
Old 03-20-2020, 09:34 AM
Evermore Evermore is offline
I dealt with this for awhile until I found a permanent solution.
1. Create a new project or open a template.
2. Open the Bounce window.
3. Make any adjustments to your liking and then bounce. Project can be empty.
4. Save to a template.
Now you will have those settings when using that template. This also works for other windows like commit etc...
Hope that helps!
Old 03-20-2020, 02:32 PM
nedd nedd is offline
Hope that helps!
That is exactly what I also discover some years ago and since then bounce format (and I believe the location too) will always stay the same as in template it comes from.
Old 03-20-2020, 05:21 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Thankfully mine does the same
Rob
MBP 15” 2018 macOS Mojave 10.14.6 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2020.3-23.# - HEAT applied, Cubase 9.5,
Yamaha TF5, UR44, BEHA4700
........and a bowl of M&M's
Can't change default format/path order in I/O dalonso66 Pro Tools HDX & HD Native Systems (Mac) 13 12-04-2019 02:35 AM
Set up Default project format? nicktunes Pro Tools M-Powered (Mac) 1 02-22-2011 08:53 AM
Speed change when dropping interleaved file on track Steve Canuck Pro Tools TDM Systems (Mac) 2 07-30-2010 08:35 AM
Can you change the default channel order of an interleaved.. dj_grimmace Post - Surround - Video 4 11-12-2007 08:10 AM
Default optical format MaizeBass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-03-2002 02:43 AM
