Old 03-20-2020, 05:24 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Default Re: change Default bounce format to interleaved
Originally Posted by Evermore View Post
I dealt with this for awhile until I found a permanent solution.
1. Create a new project or open a template.
2. Open the Bounce window.
3. Make any adjustments to your liking and then bounce. Project can be empty.
4. Save to a template.
Now you will have those settings when using that template. This also works for other windows like commit etc...
Hope that helps!
Creating templates saves a lot of unnecessary work imo.
Rob
MBP 15” 2018 macOS Mojave 10.14.6 Touch Bar and ID
Pro Tools 2020.3-23.# - HEAT applied, Cubase 9.5,
Yamaha TF5, UR44, BEHA4700
........and a bowl of M&M's
Old 03-21-2020, 09:45 AM
Evermore Evermore is offline
Agreed! Best solution in keeping things nice and neat.
Pro Tools 2020.5
Mojave 10.14.6
iMac i7 4.0
Apogee Symphony IO
Old 03-21-2020, 04:47 PM
Samba Samba is offline
Hope that helps!
Legend! Thanks!
ANy chance Avid will fix this? I can't wee why we would want to default to anything apart from stereo interleaved
Old 03-22-2020, 01:21 PM
Originally Posted by Samba View Post
Legend! Thanks!
You're Welcome!
Couldn't say...Avid might not consider this as a bug and most likely see it as a working/workflow preference. Maybe submit a ticket and see what they say.
Pro Tools 2020.5
Mojave 10.14.6
iMac i7 4.0
Apogee Symphony IO
Can't change default format/path order in I/O dalonso66 Pro Tools HDX & HD Native Systems (Mac) 13 12-04-2019 02:35 AM
Set up Default project format? nicktunes Pro Tools M-Powered (Mac) 1 02-22-2011 08:53 AM
Speed change when dropping interleaved file on track Steve Canuck Pro Tools TDM Systems (Mac) 2 07-30-2010 08:35 AM
Can you change the default channel order of an interleaved.. dj_grimmace Post - Surround - Video 4 11-12-2007 08:10 AM
Default optical format MaizeBass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-03-2002 02:43 AM
