does eleven rack make LE out of the box ?
unless Russ can show me some tricks for vocals on this then i have no use for it. But avid has mad me a proud fan boy today now i can tell those logic heads to s*ck it. and hopefully this is just the beginning
does the dsp make it out the box and can u use it with 003 or will they push the command8 (witch its time for a new one) by the way i would love to hear about the eleven rack |
Re: does eleven rack make LE out of the box ?
I'm reading your question as being "Does Eleven Rack function as a Pro Tools LE interface and come with a copy of PTLE"
From what I read of the manual, yes The DSP stays in the box although you could theoretically run tracks out to the interface and then re record them using the effects and models. You can use it with the 003 but you will need to cable it in since the USB cable will only transfer data when both units are active.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
You can also run any input, including the Mic, through the Rig effects. You can use it with a 003 just like you would with any other hardware effect device, either as a hardware IO or a send/return, and control it using the Eleven window in Pro Tools. |
cool thanks for the response
now if we can get russ to show some vocal tricks on this thing i ll get this instead of the uad with the fatso plug. |
can all analog inputs be used at the same time?
and routed to different tracks in PTLE? gtr input jack mic xlr jack line R jack line L jack
17" MBP i7, 4GB RAM, Profire 2626, PT-MP 8 |
Yes, absolutely, as long as the Eleven Rack is the primary interface - if it's not (when used with an HD or MP system for instance) only the physical IO can be used, though you can route any input to an output for recording.
The two units cannot be used as I/O in PT at the same time? If so, forgive me but, that sucks.
We knew this would be an issue with some - as I mentioned in a different thread, the reason it wasn't implemented this way is that the whole mechanism for how PT detects interfaces would need to be reworked and which would require a significant amount of engineering time and would have a massive impact on all current projects, causing delays - something we cannot afford right now. We felt that engineering time was better spent on other projects and to keep things on schedule.
Can you use the mic input through the effects loop, to insert a compressor or what have you?
BTW inserts should be included in the 004 or give the ability for full bypass of the pres...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Yes! Any input can be run through the 'Rig' chain and you can order fx/cabs/amp any way you like. You can also tap off the chain anywhere and send that tap to a discrete output on the Eleven Rack.
How to connect other hardware to Eleven Rack and make it work in Pro Tools 11 | TENM | Eleven Rack | 0 | 03-11-2014 05:55 AM |
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? | Rongpat | Eleven Rack | 8 | 02-11-2014 07:42 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
Eleven Rack problems...really? Doesn't Avid make it? | Kourquie | macOS | 4 | 09-12-2011 08:11 PM |
