Old 03-25-2001, 06:05 AM
ratz ratz is offline
Default Expansion Chasis
I am considering getting an expansion chasis and have a few questions:
1) Should I go with Magma or another vendor?
2) Are the problematic and just another headache in the configuration, or once installed do they just run?
Thanks
Old 03-25-2001, 07:52 AM
Huby SEA Huby SEA is offline
Default Re: Expansion Chasis
I prefer the magma.. No hassle, but very noisy!! the vents blow like the mills in Holland..
No extension needed or whazoever: just follow the Digi compat and expansion-chassis doc.
Greetings,
Huby
Old 03-26-2001, 11:57 PM
cu_all cu_all is offline
im also looking at getting a exp-chassis, but i need itto be quite, well quiteish...any sugestions
Old 03-27-2001, 05:29 AM
proximityeffect proximityeffect is offline
IMHO,
buying a DIGI approved chassis should be the most important factor. You can always take steps to reduce noise later (fan swap, etc...)
expansion chasis help? JT916 Pro Tools TDM Systems (Mac) 6 04-28-2004 09:57 AM
Expansion Chasis for HD5 jerrahi Pro Tools TDM Systems (Mac) 1 08-12-2002 06:33 AM
expansion chasis robby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-19-2002 07:22 PM
Expansion Chasis/ 32 bit or 64 bit? blairl Pro Tools TDM Systems (Mac) 4 03-01-2002 07:02 AM
expansion chasis loutunes Pro Tools TDM Systems (Mac) 6 01-05-2000 04:59 PM
