  #2451
Old 11-05-2010, 05:59 PM
joethfc joethfc is offline
Default Re: Best Laptops for PTLE
Have been doing a mix of about 40 tracks on a Lenovo Thinkpad SL510 using just one 7200 hard drive and managing fine. If I was struggling I'd run the project from my external eSata drive.
  #2452
Old 11-12-2010, 08:19 AM
padraic padraic is offline
I have a laptop with both firewire and eSATA.Which is the best to use for recording to an external hard drive?
  #2453
Old 11-13-2010, 11:37 AM
QuikDraw QuikDraw is offline
This computer doesn't belong in the "Best Laptops" thread, but there doesn't seem to be a better place to post this...
I picked up a Fujitsu AH530 laptop basically for office work, but I figured since i3's typically perform better than Core 2 Duo's it might be worth trying with Pro Tools. It's not a powerhouse, but it does work. And it's cheap! I picked it up for $600.
The actual audio drive I'm using isn't listed in the Sandra report below because it wasn't connected at the time I ran the test. It's a 7200 rpm Western Digital Caviar 120GB IDE on USB2. It's about 7 or 8 years old. I used to use it with my Digi001 system. Yes, I've always used USB2 drives! It's cool that they're actually supported now on PT9!
I'm only getting 66 DVerbs in the DVerb 2 test, but that's not bad for a budget computer with a USB2 audio drive and absolutely zero optimizations. And my desktop gadgets are running as well as my wireless adapter, anti-virus, and everything else. Like I said, zero optimizations and zero tweaking.
I'm running PTLE 8.0.4cs2 with an MBox 2 Mini.
Windows 7 Pro 64-bit
SiSoftware Sandra
Computer
Model : FUJITSU LIFEBOOK AH530
Workgroup : MSHOME
Host Name : Mike-Laptop
User : Mike
Processor
Model : Intel(R) Core(TM) i3 CPU M 350 @ 2.27GHz
Speed : 2.26GHz
Cores per Processor : 2 Unit(s)
Threads per Core : 2 Unit(s)
Type : Mobile, Dual-Core
Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 3MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 4 threads sharing
Computer
Platform Compliance : Intel Centrino Mobile Technology
Mainboard : FUJITSU FJNBB06
BIOS : FUJITSU // Phoenix Technologies Ltd. Version 1.12 05/24/2010
Bus(es) : X-Bus PCI PCIe IMB PCMCIA USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 3.8GB DDR3 SO-DIMM
Chipset
Model : Fujitsu Core (Auburndale/Havendale) DRAM Controller
Front Side Bus Speed : 1x 133MHz (133MHz)
Total Memory : 4GB DDR3 SO-DIMM
Shared Memory : 34MB
Channels : 2
Memory Bus Speed : 2x 532MHz (1GHz)
Memory Module(s)
Memory Module : Samsung M471B5673FH0-CH9 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Video Adapter : Intel(R) Graphics Media Accelerator HD (12 SM4.0 667MHz, 64MB DDR3 2x533MHz, Integrated Graphics)
Graphics Processor
Storage Devices
WDC WD5000BEVT-16A0RT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 466GB (C:) (D:)
SAMSUNG HD105SI (1TB, USB/SATA, 3.5", 7200rpm) : 932GB (F:)
TSSTcorp CDDVDW TS-L633B (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
Hard Disk : 200MB (NTFS)
Iomega HDD (F:) : 932GB (NTFS) @ SAMSUNG HD105SI (1TB, USB/SATA, 3.5", 7200rpm)
Hard Disk (C:) : 225GB (NTFS) @ WDC WD5000BEVT-16A0RT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache)
Hard Disk (D:) : 225GB (NTFS) @ WDC WD5000BEVT-16A0RT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache)
Hard Disk : 16GB (NTFS)
Optical Drive (E:) : N/A @ TSSTcorp CDDVDW TS-L633B (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Fujitsu HM55 LPC Interface Controller
LPC Legacy Controller 1 : Winbond W83687THF
Audio Device : Fujitsu P55/PM55/3400 High Definition Audio
Audio Codec : Realtek Semiconductor High Definition Audio
Disk Controller : Fujitsu P55/PM55/3400 4 port SATA AHCI Controller
USB Controller 1 : Fujitsu P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 2 : Fujitsu P55/PM55/3400 USB2 Enhanced Host Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : hp LaserJet 1012 HB (600x600)
Printer : Brother PC-FAX v.2 (200x200)
Printer : Brother MFC-420CN USB Printer (Colour)
Scanners and Cameras
Scanner : Brother MFC-420CN LAN (Scanner, 600x2400, USB)
Network Services
Network Adapter : Bluetooth Device (Personal Area Network)
Network Adapter : Realtek PCIe GBE Family Controller
Network Adapter : Check Point Virtual Network Adapter For SSL Network Extender
Wireless Adapter 1 : Atheros AR9285 Wireless Network Adapter (802.11g (ERP), WEP n-bit, 54Mbps)
Power Management
Mains (AC) Line Status : On-Line
Battery No 1 : 100%
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 4.5
  #2454
Old 11-29-2010, 12:00 PM
IndieNick2 IndieNick2 is offline
Hey all,
I'm looking to get a new laptop and PT9. Two questions...
1. Thoughts on HP Pavilion DV6-3052NR NoteBook Intel Core i7 720QM(1.60GHz) 15.6" 6GB Memory 500GB HDD 7200rpm DVD Super Multi ATI Mobility Radeon HD 5650 ?
2. I currently run PTLE 7.4. I'm looking to get the upgrade for PT9, so would I have to install 7.4 on the new machine first? From what I've read, it will not run on Windows 7. Will it at least install properly so I can then buy the upgrade? Or are there other steps that I need to take?
I'm currently using an Mbox 2 mini for PTLE 7.4 on an older Dell desktop running XP.
Thanks!
Windows 7 64bit
HP Pavillion DV6
i7 740
6G RAM
500G WD My Book Ext. HD
Pro Tools 9.0.1
Mbox 2 Mini
  #2455
Old 11-29-2010, 12:03 PM
spkguitar's Avatar
Originally Posted by IndieNick2 View Post
2. I currently run PTLE 7.4. I'm looking to get the upgrade for PT9, so would I have to install 7.4 on the new machine first? From what I've read, it will not run on Windows 7. Will it at least install properly so I can then buy the upgrade? Or are there other steps that I need to take.
PT9 is a full installer; you do not need an older version installed.
Sorry; no opinions on that laptop.
  #2456
Old 11-29-2010, 01:15 PM
ValkRider ValkRider is offline
Using Pro Tools 9, do you think this could be used?
I can't find anything refering to an HP in the threads, hoping some one can give me an idea. Thanks
Specs:
HP Pavillion dv7tse series
Operating system Genuine Windows 7 Pro 64-bit
OS and recovery media System Recovery DVD with Genuine Windows 7 Pro 64-bit
Processor Intel(R) Core(TM) i7-740QM Quad Core processor (1.73GHz, 6MB L3 Cache) w/Turbo Boost up to 2.93 GHz
Graphics card 1GB ATI Mobility Radeon(TM) HD 5650 graphics [HDMI, VGA] - For Quad Core Processors
Memory FREE Upgrade to 8GB DDR3 System Memory (2 Dimm)
Hard drive 1TB 7200RPM Dual Hard Drive (500GB x 2) with HP ProtectSmart Hard Drive Protection
Primary battery 9 Cell Lithium Ion Battery (over-sized)
Display 17.3" diagonal HD+ High-Definition HP LED BrightView Widescreen Display (1600 x 900)
Primary optical drive FREE Upgrade to Blu-ray player & Lightscribe SuperMulti DVD burner
Personalization HP TrueVision Webcam and Fingerprint Reader
Networking Intel Wireless-N Card
Keyboard Standard Keyboard
"So it goes", Kilgore Trout
  #2457
Old 11-29-2010, 01:45 PM
This goes for the crossgrade from LE as well?
Windows 7 64bit
HP Pavillion DV6
i7 740
6G RAM
Pro Tools 9.0.1
Mbox 2 Mini
  #2458
Old 11-29-2010, 10:01 PM
remis remis is offline
Yep If you purchase the download you have two options that you can download (at any point, and as many times as you like) from within your Avid account. One is the full installer, and the other is an updated installer (used if you already have an older version of PT on your machine). It's recommended that you use the full installer though.
And if you purchase the boxed version of the crossgrade then the disc has the full installer anyway. The crossgrade only uses your hardware serial number, that's about the only thing that makes the crossgrade different from the retail pack (new ilok excluded). I even noticed in my Avid account yesterday that I can now download the loops and stuff that come with the boxed discs (which appear to be exactly the same as the loops from PT8).
PT10, Focusrite Liquid Saffire 56, Eleven Rack, i7 950 @3.80GHz, Noctua NH-D14 CPU cooler, GA-X58A-UD3R, Corsair CMD12GX3M6A1600C8 12GB, SAPPHIRE VAPOR-X HD5770 1GB GDDR5 PCIE, Caviar Black 500GB 32MB Cache OS drive, 2x Caviar Black 1TB 64MB Cache Sata3 (Audio and library), Broadcom BCM94322MC wireless network adapter
W7 - 312 dverbs @ 64 buffer/ 403 dverbs @ 1024
  #2459
Old 11-30-2010, 12:33 AM
dongiovanni1986 dongiovanni1986 is offline
Random-my laptop and p-tools software were stolen....need help getting information regarding the re-install/download of m-powered 8 for my new computer. already have my authorized ilok but dont know where to get software rom. avid has not yet responded to this issue and its a time sensitive matter. any assistance is greatly appreciated. thank you!
  #2460
Old 11-30-2010, 07:11 AM
Noviisi Noviisi is offline
Originally Posted by buzzroll View Post
Just bought a Sony VAIO VPCF13PFX/B, the ILink 4-pin port does not have a texas instrument chip set - it would allow me to enter PTLE8.0.4 but I could not switch to ext clock (I use an Apogee for clock). I am not sure what other problems, if any, I would have discovered as I immediately plugged my SIIG firewire 400 PCIexpress card and everything worked like magic.
Do you mean this?
http://www.siig.com/ViewProduct.aspx?pn=NN-EC2012-S1
002R MacBook Pro 15" Focusrite Rode Shure Waves ToonTrack
USB support with Pro Tools 9 Laptops moldenke Pro Tools 9 4 11-18-2010 04:46 PM
Dell Laptops and Pro Tools sgladm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-03-2006 10:32 AM
Best laptops for Pro tools felixflank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 04-07-2006 06:41 AM
alien laptops and pro tools geefive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-29-2006 10:17 AM
Pro Tools and Apple laptops Jsalam112 Pro Tools TDM Systems (Mac) 1 04-08-2002 09:28 AM
