Old 11-18-2018, 08:04 AM
Sean Bombz Sean Bombz is offline
Default 2018 iPad Pro usb c to Ethernet
I’m just wondering if I can connect 2018 iPad Pro to pt control app via usb c to Ethernet without using a powered hub. Thanks.
I actually had a non powered usb c hub from Anker (my wife’s) at my house. Tried it and it works!
Sean Bombz
Mac Pro late 2013 3.5GHZ 6 core 64g ram
Mojave 10.14.5
Pro tools 2019.5
Apollo x 16
Apollo 16 mk2
Apollo twin mk2
Avid S3
PT Dock
PT control (iPad)
eucon 2019.5.1
Last edited by Sean Bombz; 11-18-2018 at 05:59 PM. Reason: Answered my own question
Old 11-19-2018, 04:28 PM
reichman's Avatar
reichman reichman is offline
Default Re: 2018 iPad Pro usb c to Ethernet
Not to disappoint you, but even the non-powered hubs provide some power from the computer's bus (I also have an Anker hub that charges my phone). But the Mac's ethernet spec doesn't support power-over-ethernet, so I would be very surprised if this worked.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 11-21-2018, 09:12 AM
The actual Ethernet connection works but won’t power the iPad. But with the hub I can connect usb c to power and I can power iPad. I couldn’t get that to happen with my old iPad using lightning and powered hub
Sean Bombz
Mojave 10.14.5
Pro tools 2019.5
Apollo x 16
Apollo 16 mk2
Apollo twin mk2
Avid S3
PT Dock
PT control (iPad)
eucon 2019.5.1
Old 05-22-2019, 03:11 PM
gersonlazoq gersonlazoq is offline
You can actually use PT Control from your iPad connected to a USB-C port on your computer or dock, without the need of wifi or ethernet connection. Just connect the iPad, enable wifi so it is recognized at first by Eucon, go to Eucon in system preferences and select iPad USB from the network interface and then disable the wifi in the iPad. Disconnect it, close PT control app, open it agin, restart Eucon applications from the drop down menu and that should have your iPad recognized over the USB interface and charge the iPad at the same time.
Best!
Bassist | Producer | Recording & Mixing Engineer | Arranger | Composer
Mac Pro Late 2013 | 2.7GHz 12-Core Intel Xeon E5-2697v2 Processor | 64GB of 1866MHz DDR3 ECC | 1TB PCIe-based SSD | Dual AMD FirePro D700 GPUs with 6GB of GDDR5 VRAM each
macOS Mojave 10.14.5
UAD Apollo x8p
UAD Satellite Octo Thunderbolt
UAD Satellite Quad Thunderbolt
Focal Alpha 65
Furman M-8x2 Power Conditioner
Avid S3 Control Surface
Pro tools Ultimate 2019.5
EUCON 19.5.1
Pro Tools Control 19.5
iPad Pro Late 2018 | 12.9-inch | Wi‑Fi | 64GB
Ken Smith Bass 6 Elite
Aguilar Tone Hammer 500
Epifani T112
Jazz Composition/Performance/Music Production & Engineering candidate at
Berklee College of Music
Old 10-09-2019, 06:12 AM
Joris de Man Joris de Man is offline
THANK YOU! I thought this was possible, but never figured out how to do it...this is great, thank you so much for sharing!
iPad Pro, Pro Tools Dock, ethernet connectivity issue? rbeggs Avid S1, S3, Dock and Control App 4 05-08-2019 06:36 AM
ipad app PT Control and PT 2018.10 babaorum Avid S1, S3, Dock and Control App 0 11-18-2018 12:52 AM
Avid says we have to use Ethernet, so it means using iPad's battery? Mattian Avid S1, S3, Dock and Control App 7 09-20-2018 02:19 PM
Ipad with ethernet! New solution with the new apple USB3 camera adapter Ale Post - Surround - Video 8 05-26-2016 07:06 AM
Ipad PTcontrol with ethernet connection Ale Avid S1, S3, Dock and Control App 1 02-16-2016 09:08 AM
