Focusrite Saffire Pro 40 and 56 Linked - WOW
You're not supposed to be able to do this, but I linked a Focusrite Saffire Pro 40 and Liquid 56 via firewire and got this:
http://home.comcast.net/~cwsand/saffire.html I haven't fully tested it or set it up yet but DANG! Everything seems to be working fine so far - even though I know I can't use all the I/O simultaneously. Anyone else tried this?
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Re: Focusrite Saffire Pro 40 and 56 Linked - WOW
Be sure to post what you find out by testing. There are many of us with the Liquid Saffire 56. If it works as it sounds, some of us may be looking to buy the Saffire 40 too.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Hi there,
Using any two Saffires together will aggregate them using dual unit mode. From our testing, we found that two Pro 40s worked well together on many systems but using a Liquid Saffire 56 and a Saffire Pro 40, or two Liquid Saffire 56s was too much for some systems due to the bandwidth involved. As such, this is why we recommend against it and do not officially support it. However, in saying this, there is no reason why this shouldn't work and, if you can get it to work well on your system then by all means continue using your 48 in and 48 out system! The good thing about firewire is that the isochronous bandwidth is reserved when the device is on the bus so, if the system is reliable then it shouldn't change too much depending on whether you're passing 2 channels of audio or 96. Best of luck with this system and we'd love to hear how you get on with it. Joe Focusrite Tech Support |
Thanks for the post;
I use my Saffire Pro 40 every day in the studio and am currently replacing all of my location racks with Focusrite. I love the drivers, the user interface is the second best in the world, and the company has been fantastic to work with. Now that PT supports it, I have moved from Sonar/Samplitude to PT for 90% of my work. Make music! -D |
Best choice I made was going with the LS56.
Next stop... is going to be expensive.... |
Hey guys just wondering is the Fcusrite series of interfaces compatible with pro tools?
Uh...yeah
absolutely love my LS56...just not a big fan of the mix control,if i was going to use more complicated setups it woud be fine but for recording and mixing in pro tools its just another layer of hassle,pro tools mixer pretty much does all the routing I need sooooo can we mabey get rid of that somehow for pro tools????I have every channel going out to a mixer and my monitoring setup is routed through there sooooo yeah the mixcontrol is overkill.Freaking sounds awesome tho,and seems rock solid....love focusrite gear...pretty much if it says JBL (harmon),Focusrite,or SSL ....I gotta check it out...have loved very thing I have used from those brands.
https://scontent-b-dfw.xx.fbcdn.net/..._3222165_n.jpg |
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Anyone using Focusrite Saffire Pro 14 with PT 11? | MijacOnAir | Third Party Interfaces | 9 | 09-27-2013 08:25 PM |
PT9 with Focusrite Saffire 56 - with a Mac | YYR123 | macOS | 2 | 02-23-2012 01:14 PM |
002 and Focusrite saffire 56 | Wess West | Pro Tools 10 | 9 | 11-23-2011 01:21 PM |
Anyone using a Focusrite Saffire Pro 26 I/O ? | Ru_C | macOS | 1 | 03-17-2011 09:51 PM |
Focusrite Saffire 56 with PT9 | Meads | Pro Tools 9 | 126 | 02-01-2011 07:34 AM |
