Old 02-20-2008, 08:39 PM
2fast4ya 2fast4ya is offline
Default Vocal Effect I can\'t figure out how to do
Hi everyone
there's an effect that out there that I've heard dozens of times that I can't figure out how to do. I like to call this effect the poltrageist effect. It sounds to me like it's a combination of a delay and reverb, but the effect happens before anyone even speaks... here are some examples
2pac - Dear Mr president
THE effect happens at 3:20 and ends at 3:25
http://www.youtube.com/watch?v=ZQx4Z...eature=related
The Simpsons: Homer 3
The effect occurs at 1:42 when Homer is talking
http://profile.imeem.com/dmY6Xl/vide..._comedy_video/
If you can help me out with this, i would GREATLY appreciate it.
I'm using Pro Tools 7.3, and I have the factory plugins. How can this be done using Pro Tools?
Thanks in advance
Jack
Old 02-21-2008, 12:50 AM
bblue bblue is offline
Default Re: Vocal Effect I can\'t figure out how to do
The Simpson piece has two or three different effects in it. The one I think you're referring to is actually pretty simple to do. Just isolate the section in question (perhaps on another track) and flip it end for end (e.g. with 'reverse' in AudioSuite). While that section is backwards apply an appropriate echo or other effect to it. When done, reverse it back. The trailing of the echo when the section is reversed, will precede the track when played forward. There's lot's of interesting effects you can create with this, so just experiment to find the right sound for you.
There may be plug-ins that can do at least some of this for you, but the sound of the effect may be limited in some way.
Asus P6T DLX, Intel i7-920 OC'd to 3.2GHz, 6GB DDR3-1600 (triple), Win XP Pro SP3, PTLE 8cs2, MPTK2, Black Lion 003R, UAD-2 Duo, UA 2192
Monitoring: 24-bit dig to Avocet Crane Song controller, Pass Labs x250.5 amp, B&K N801 monitors, Transparent Audio analog cabling
Old 02-21-2008, 02:25 AM
andrewSF andrewSF is offline
Yep, sounds like you're looking for a reverse echo effect, also called reverse reverb or sometimes "preverb." Follow what Mr. Blue suggested and you'll see how it works. When you're applying the effect with AudioSuite remember to leave extra time for the echo/verb/whatever to decay completely.
Old 02-21-2008, 09:36 AM
tbkbt tbkbt is offline
http://www.soundonsound.com/sos/dec9...everse.665.htm heres an article from SOS to help.
Old 02-24-2008, 03:49 PM
That works perfectly. Thanks a lot guys.
Getting a Certain Vocal Effect DonaldM Tips & Tricks 14 05-22-2013 01:13 PM
How to do that vocal effect - Hey Ya Naagzh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-10-2003 08:55 AM
Name That Vocal Effect kidmixalot Tips & Tricks 1 08-02-2003 02:41 AM
Finally a new vocal effect to put the Cher effect to bed!!! ***BboY *** 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-22-2002 09:11 PM
Perfect vocal tuning..Fast!!It's time to figure this out. Stratman Tips & Tricks 2 11-29-2000 11:18 AM
