Old 11-22-2014, 09:40 AM
Default BUG 11.2.2: black wink when using pre-roll
Can anyone confirm this:
1) set pre-roll to 1 sec and turn on loop-playback.
2) make a selection.
3) hit play
notice the picture go black like the blink of an eye exactly at the in-point of your selection after the pre-roll?
Only happens when pre-roll and loop-playback are on. Without loop-playback it works fine.
Anyone seeing this? Happens on both the QT window and the output of the BM card.
Thanks,
Frank.
PTHDn 2019.6 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 11-23-2014, 07:23 AM
Speedsound Speedsound is offline
Default Re: BUG 12.2.2: black wink when using pre-rol
Hello,
I can confirm .
Same problem as you
PTOOLS HD 11.2.2/BM Driver 10.3.1
3) hit play
Thanks,
Frank.
Old 11-23-2014, 07:27 AM
Thanks!
Posted to IS:
http://protools.ideascale.com/a/dtd/136187-3779
Old 11-23-2014, 02:57 PM
Buccanears's Avatar
Buccanears Buccanears is offline
I've just tried this on a test rig with Mavericks and then Yosemite running 11.2.2 HDX. Admittedly, I'm not running a BM card in the system at the moment, but I'm not getting any blinking with QT window using QT or MXF video media with loop playback and 1 sec pre roll.
I've found my Mountain Lion drive, and yes, it is flashing a black winky.
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 11-24-2014, 01:02 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Confirmed. I am with Aja Kona LHi card.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2019.6 Ultimate ● macOS High Sierra 10.13.4
MacPro 2 x 2.4 GHz Quad-Core Intel Xeon ● 24 GB RAM
Avid HD I/O ● Sync HD ● AJA LHi referenced by AJA GEN10 ● D-Command ES24
Old 11-24-2014, 01:28 AM
Buccanears's Avatar
It's Mountain Goat...
As long as it doesn't lose sync, I'm sorta ok with this, as it is now 2 x OS backwards. It would be nice to see a 10.3.10 to fix input monitoring and black winky though.
IMDB
Old 11-24-2014, 01:49 AM
Thanks for the info. So mavericks and beyond are OK, but those will break 10+11 co-installs correct?
Thanks again,
Frank.
BTW: How can I update to Mavericks from 10.8.5? Appstore only ever offers the latest OS (Yosemite) or am I missing something?
Old 11-24-2014, 02:04 AM
mgoorevich's Avatar
Thanks again,
Frank.
Frank, try this:
Sign in to the App Store, go to the Purchases, I can see the Maverick is available for downloading then.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
Old 11-24-2014, 02:20 AM
Originally Posted by mgoorevich View Post
Frank, try this:
great, thanks!
Frank.
Old 11-24-2014, 06:56 AM
mgoorevich's Avatar
Same behaviour in 10.9.5 and HD 11.2.2.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
HTML code is On
Pre-roll/post-roll appears to be broken in PT10 anodecathode macOS 1 02-20-2012 01:33 PM
nudge nudge wink wink paldry macOS 2 09-09-2011 08:21 AM
Pre-roll doesn't work but post-roll does :confused: pennard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-06-2009 11:26 PM
Pre roll and Post roll keyboard commands? Bob L 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-30-2007 07:46 AM
Roll up, roll up - Get your Free RTAS Plugins... Tanglewoodstu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 08-24-2005 09:46 AM
