Old 08-02-2016, 12:28 PM
PT8716 PT8716 is offline
Default Re: 11R Standalone Editor Won't Install
Is it possible that one of the optimizations is blocking this from working?
Old 08-02-2016, 12:48 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default 11R Standalone Editor Won't Install
Not usually,
I am assuming that there was an install for x32bit and x64 bit app?
I am a Mac guy so I am out of options/ideas
Is your 11 rack configured for the default sound playback device in the windows control panel?
Daniel
Old 08-02-2016, 12:52 PM
Benoni's Avatar
Benoni Benoni is offline
Have you tired using a different USB port or cable? Are you plugged into the computer or into a hub?
I would uninstall the editor and then reinstall it.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 08-02-2016, 01:59 PM
Just un-then-reinstalled 11R Driver, Quicktime and when I try to install the editor it says that it needs to install pace software(which is already on my computer) It says it needs to reboot, I click ok, reboot and...nothing.
Old 08-02-2016, 02:07 PM
When I say nothing it won't even install now.
  #16
Old 08-02-2016, 04:17 PM
Is there and intaller that doesn't prompt to install the pace software?
  #17
Old 08-02-2016, 05:24 PM
YYR123's Avatar
No probably not.....
Maybe you can try messing around with the monitor resolution? Maybe lowering it, will help, it's possible.
What video card are you running?
Daniel
  #18
Old 08-02-2016, 06:15 PM
Wow! I changed from HDMI cable to VGA. Is that really what the problem was?
  #19
Old 08-02-2016, 06:16 PM
YYR123's Avatar
Wow super cool....switch back and see
Daniel
  #20
Old 08-02-2016, 06:34 PM
Switched back to HDMI and these popped up. Then it said Windows will run in compatability mode(which I tried many times earlier) next time I launch application and it worked! Phew!
Eleven Rack Standalone Editor brianiac5150 Eleven Rack 315 02-07-2015 04:53 PM
Eleven Rack standalone editor won't install on Windows 8.1 prkaye Eleven Rack 2 03-28-2014 10:11 AM
So where are we now with the Standalone Editor? sorcerer27 Eleven Rack 22 12-29-2012 01:33 PM
Standalone Audio Editor manilarice 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 09-28-2010 02:55 PM
D-Show standalone editor 2.8 and 2.7 on same PC? milkyco VENUE Live Sound Systems 5 04-08-2010 02:19 AM
