Old 07-23-2014, 01:33 PM
Jerry K. Jerry K. is offline
Default Sample Rate
I am all of the sudden getting this message. "Could not complete the Open Session... command because Pro Tools could not set sample rate to specified value". PT won't let me open old or create new sessions, I get the same error every time. I am using the MOTU 896 as my interface on Win 8.1 and my system has been rock solid for about 8 months. I did switch my sample rate inside the MOTU audio console from 44.1 to 48 yesterday and switched it back to 44.1 today. I have tried restarting the machine and nothing seems to work. Everything else seems to be working fine on my computer. Any help or advice is greatly appreciated.
Thanks
Jerry Kelley
[email protected]
www.jlkstudio.com
Old 07-23-2014, 01:41 PM
Raoul23 Raoul23 is offline
Default Re: Sample Rate
Have you tried to import session data into a new session and open it that way. It might be a corrupt session ?
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 07-23-2014, 01:47 PM
I was finally able to get it to let me create a blank session and then I was able to open an older session. I successfully tried bouncing to disk and then opened yet another session and PT shuts down and gives me a runtime error. I had to repeat the entire process again and get the exact same results. I also noticed that someone in the PT 11 forum has also posted a similar sample rate issue.
Jerry Kelley
[email protected]
www.jlkstudio.com
Old 07-23-2014, 03:35 PM
I ran the repair feature from the 11.2 update and it did not help. If I uninstall PT from control panel are there other things I need to do to ensure a clean install (reg etc)?
Thanks
Jerry Kelley
[email protected]
www.jlkstudio.com
Old 07-23-2014, 09:14 PM
Sounds like your clock is set to external with no valid clock source.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up finalcut Windows 12 02-20-2012 04:00 AM
Bit Rate / Sample rate supersam83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-25-2010 08:55 PM
MBox Micro Sample Max Sample Rate Only 48 kHz? Joe Sciacca 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-07-2008 12:52 PM
Bit Rate/Sample Rate problem? The chipmunks? bspro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-17-2008 05:40 PM
Bit rate & Sample Rate WizDoomBorn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-02-2002 12:54 AM
