freeze function or equivalent in Pro Tools?
Is there a simple way to freeze/lock a track?
Thanks |
Re: freeze function or equivalent in Pro Tools?
Its in one of the menus, edit I think but might be region. Lock / Unlock
Peter |
Thanks, man.
That's not what I need. I meant freezing a track to relieve CPU. Like in Live or Garage band and other DAW's. |
So is there a simple way to do it in PT?
Thanks |
You can use the audio suite version of the plugs on the audio then bypass the plug. I haven't really ever done it but I'm sure some other can explain how better than I could.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
There is no equivalent of the "freeze" in logic. As the previous user mentioned using the audiosuite versions of your "live" plugs can get around this, just place a processed version in a unique playlist on its current track.
I haven't done it, and it wouldn't be as simple as the logic freeze function but it is the only way in PT i'm afraid.
G5 dp 2.0Ghz, 2.5 gb RAM/ G4 Powerbook 15" 1.33mhz, 2gb RAM/ 002r/Lacie D2 FW800/PTLE 7.4 |
I thought it would be essential especially in LE.
add it to the list along with ADC!
If there are multiple plugins on the track, it may be quicker to print the track to another audio track
G5 Dual 1.8 /1.5 Gb Ram OSX 10.4.7 PT LE 7.3 cs1 DIGI 002 Waves Ren Sony Bundle Soundtoys-arama NI Komplete 3 |
An addition to all above, you may want to go back to your original track sometime, so duplicating the playlist and renaming it something meaningful (i.e. Guitars WET) before applying any effect is a good option.
If you have automation on your tracks offline processing is no good. Route your track to a free (pair of) Bus, create a new audio track, select that Bus as input of new audio track and record it. than you can disable the original track to free up cpu.
HD3 + Control 24 + 2 192s Mac Pro 12 core 2.93 & PT 8 16 Gig RAM Glyph Firewires Motu MTP AV USB |
Freeze function | pgripp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-21-2008 07:12 PM |
FREEZE FUNCTION!!! | alw4416 | Pro Tools TDM Systems (Mac) | 10 | 12-25-2007 01:02 PM |
Freeze Function?? | chriscalyx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-09-2007 09:50 PM |
PT freeze function? | chuck.dallas | Pro Tools TDM Systems (Mac) | 1 | 02-03-2007 06:46 PM |
PT 6 equivalent of LA 6 "freeze" function? | Carder | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 04-26-2003 08:29 AM |
