Good gate, compressor, and limiter settings
For hip-hop vocals. I've been experimenting for a while, and just when I think I've found a good setting, it'll end up sounding crappy. I'm mainly concerned with the gate and limiter. I know my way around a compressor but don't have much experience gating/limiting. And please don't come with the whole "I can't tell you good settings cuz vocals change from track to track" deal. I've been recording vocals for a while, so I know this. Just some tips is what I'm looking for. But I digress. Any advice would be appreciated. Peace.
Re: Good gate, compressor, and limiter settings
I just did some gate experimentation, and found you can circle the globe about three times with settings without repeating a gates performance. Luckily, I didn't need absolute silence, so I went for the -6db to drop it out of the audible mix. Find your threshold first. My "breakthrough" was finding the right attack time so the gate never banged/clicked on. Then I found the appropriate delay or decay (crap, can't think!) to hold the gate open through an average phrase or musical decay.
It ended up being VERY helpful! And this was the Digi gate.
002R Win7, no PT GigaByte 970A-UD3/AMD FX(tm)-8120 8GB DIMM DDR3 AMD Radeon HD 6570 2 WDC WD10EURX-63FH1Y0 www.soundchasm.com |
Personally, I never use a gate plugin. I would rather automate the level or cut out the background noise and put short fades on each end of the remaining audio. Once that is all done, I consolidate the track. This works great on tom tracks, bass and guitar tracks as well as vocal tracks to get rid of headphone bleed and the singer that keeps bumping the mic stand. Compressors-for vocals I generally set at 4:1 and adjust threshold for 4-6db of reduction. Which compressor plugin you use will make as much difference as the settings. My personal fav is the Bomb Factory BF76. I will likely add a bit of high EQ after the compressor. For that, I love the Bomb Factory Pultec EQ set to 10K and +3 or 4. If I need to de-ess, I do it before the compressor with Waves de-esser.
Where is the DEMO for the AVID Pro compressor , limiter and noise gate . | P,B,S | AAX Plug-ins | 13 | 02-25-2013 10:29 AM |
RTAS Compressor Limiter settings help? | Angelo of Onello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 20 | 11-24-2008 08:45 PM |
Gate and Limiter plug-ins absent from LE 7.4? | galbright | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-03-2008 01:37 PM |
Good Limiter/Compression Settings for Radio Commercials | r steele | Tips & Tricks | 7 | 12-22-2002 02:48 PM |
good compressor/limiter for VO + vocals | procontrolmomma | Pro Tools TDM Systems (Mac) | 5 | 10-31-2001 04:42 PM |
