Using a computer monitor for video?
I'm setting up a home mix rig using a 2011 iMac (I know, but it was the top of the line and it's been incredible). I've been looking for a "real" video output solution. I found a Sonnet Echo Express SE 1 and I'm searching for a Kona LHi card.
But I get this sense that people are just running desktop video from a Pro Tools window (or maybe a lot more than are willing to admit). I have to say, after I set the proper offset it seems very consistent just feeding a TV with HDMI. I'll still go with the proper solution, but curious what people are doing. Throwing plug-ins and other windows on the screen when you need to is certainly a nice bonus. |
Re: Using a computer monitor for video?
I don't know about the Imac, but in Windows I just stretch the desktop across 3 monitors and resize the video image.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
Same thing here.
I'm on a 2009 Mac Pro (upgraded to 2012). Even if there's a Blackmagic Intensity 4k installed, I'm running a 3 monitor setup straight from the graphic card..... Bonus point, being able to use the third monitor as computer monitor whenever possible: edit window, mix window, plugins, Dolby Atmos Production Suite.... you get the picture.
Luca de Sensi |
Maybe get a TV with multiple HDMI inputs and feed the computer AND a video interface so you can switch as needed. That's what I've been doing, especially recently with Source Live Pro.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
Thanks for the feedback, and for the pic Wizzoboy.
Instead of asking my question specifically about computer monitors, I should’ve asked, “How many of you are using the Pro Tools video window instead of a dedicated video interface?”... regardless of sending it to a computer monitor OR a TV. When you say sync is sloppy on a computer monitor, I assume the results were the same if the monitor was a TV? — you’re still using PT’s video window. For working alone, the menu bar and the color is a drag but not a deal breaker. However, as a mixer, the sync has to be accurate. |
In the video hardware world, there are two categories: 1. devices like T-Tap or some lower-end Blackmagic cards without genlock that give very good sync, much better than PT window. 2. devices like the high-end Kona cards that have genlock and will give you 100% frame-edge sync. IME, the T-Tap has been so tight, that I don't feel like I need genlock, but on the big stages, genlock is commonplace.
Thanks. I’m aware of the pro options, but the clarification is appreciated. It’s the semi-pro option I was wondering about, as it’s been a long time since I’ve tried to work that way. Your Syncheck results give the answer.
What range are we talking about - 1/4 frames or frames? |
Pro on the cheap (for 5,1 mac users)
Decklink SDI plus 30€ SDI to HDMI converter on the back of your TV. Has genlock, no fans on the card and works like a charm. These are great as they can be powered by the USB out of your TV or projector: https://www.blackmagicdesign.com/pro...icroconverters Plus you don't need crazy thick expensive HDMI cables or an additional extender to bridge the 20m+ without signal problems. SDI cables can run 100m (I think) without any additional help. F.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron Last edited by Frank Kruse; 02-14-2021 at 04:07 AM. |
Pro Tools Expert wrote a great article about this years ago. Worth searching there if you're curious.
Great idea Frank, thanks.
Great info reichman. Unpredictable sync isn't an option. |
Outputting Video To External Video Monitor | chadjhughes | Pro Tools 2019 | 3 | 01-05-2020 02:58 PM |
Video window appears on computer monitor when using scrubber tool | NvD | macOS | 0 | 03-05-2012 12:30 AM |
Where is your computer monitor placed? | DaleB | ICON & C|24 | 5 | 03-28-2011 10:53 AM |
Database... Video Monitor(s) Size & Video Card | jbr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-19-2001 02:23 PM |
Composite Video to Computer Monitor | I Forgot it | Tips & Tricks | 1 | 07-13-2001 05:05 PM |
