Old 05-14-2006, 02:53 AM
ejwells's Avatar
ejwells ejwells is offline
Default Mbox phantom power issue
A frind of mine has a two year old Mbox on which he fears the phantom power circuit has gone bad.
His symptoms are:
Hum when using a condenser, no hum when using a dynamic with the same cord.
I think he has a Rode NTK.
I told him I'd post for him to get some opinions.
If it IS the Phantom power circuit, is it worth repairing?
Anything else that springs to mind as the cause other than the phantom power?
Thanks in advance-
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Old 05-14-2006, 03:13 AM
GeoffLee GeoffLee is offline
Default Re: Mbox phantom power issue
The NTK is a valve mic and has it's own power supply and cable(which can't be used with a dynamic), so the mic probably isn't a NTK. A damaged cable may be the culprit - try using another.
2010 iMac 4gig ram, OS 10.8.5, PT12.4, Saffire Pro 40, Octopre.
2011 Macbook Pro 4gig, OS 10.10.4, PT12.4, Fast Track
Old 05-14-2006, 03:37 AM
ejwells's Avatar
You are correct sir. It's an NT1000.
I tried to explain to him that an old mike cord might work OK for a dynamic, but not carry power to a condenser.
I suggested he get a Mogami cable, and call it a freakin' day.
He's using a cable that we used when we performed together...back in 1981!
I guess my question is: has anyone out there had a phantom power supply go bad in an Mbox?
I'd think this would be a rare occurance.
Mbox Phantom Power - 2? jbmoony 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-12-2011 02:01 AM
Phantom Power Issue 003 rack + silky38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 01-03-2011 10:57 AM
Mbox 1 phantom power noise issue wolfie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-02-2009 11:43 AM
Phantom Power with the Mbox Josh Scanlan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-26-2003 06:41 PM
Help!!!To use phantom power on the Mbox.... SonnyD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-07-2003 09:48 PM
