Pro tools 8 le not responding
Protools 8 le is getting a freeze up or lock up where it does not respond to what I requested and than you get that windows not responding showing up.
Also I get alot of the 1450 errors saying not enough resources when trying to open a session, it than takes multiple trys to finally get it to open. Thanks Much |
Re: Pro tools 8 le not responding
Welcome to the forum abikambic.
We'll need to have a detailed look at your system so we can help you and see what's up. Posting a Sandra report will definitely benefit so we can see under the hood in more detail. Also, it will be good for you to read through this thread that will have additional info which will help. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Hi Shane,
Thanx much for your help. I have the software to do the Sandra report.Should I just copy and paste it here on a forum post for you? I see now that I cannot copy and paste the info for the Sandra report. How shall I get it to you? |
Tried the typical control c bluing it out way and it did not want to blue out. Will try something else when I get home from work.
Thanx Guy |
Shane
Thanx for the tip. Heres my computer breakdown. If it not enough I can give you more from Sandra.
I updated to 8.03 from 8. I also did the changes that the DigiTech post says to do for windows xp, general troubleshooting and optimizations post. Should the protools software be loaded into my E drive. Right now its in my main c drive where my operating system is and than everything gets saved into my E drive. Thanx Much SiSoftware Sandra Computer Model : System manufacturer System Product Name Workgroup : HOME Host Name : sk-qo9i0vr7rqhe User : SK Processor Model : AMD Phenom(tm) II X4 955 Processor Speed : 3.2GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 4x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size L3 On-board Cache : 6MB, ECC, Synchronous, Write-Back, 48-way, 64 byte line size, 4 threads sharing Computer Mainboard : Asus M4A785TD-V EVO BIOS : AMI 2002 03/18/2010 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.25GB DIMM DDR3 Chipset Model : ASUS RS780 Host Bridge Alternate Front Side Bus Speed : 2x 2GHz (4GHz) Total Memory : 128MB Shared Memory : 384MB Memory Bus Speed : 2x 667MHz (1.33GHz) Chipset Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub Front Side Bus Speed : 2x 2GHz (4GHz) Total Memory : 4GB DIMM DDR3 Memory Bus Speed : 2x 667MHz (1.33GHz) Memory Module(s) Memory Module : A-Data DDR3 1333G 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : A-Data DDR3 1333G 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : ATI Radeon HD 4200 (40 SP, 384MB, Integrated Graphics) Graphics Processor Adapter : ATI Radeon HD 4200 (40SP, Integrated Graphics) Storage Devices Seagate ST3160318AS (160GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 149GB (C:) Seagate ST3250318AS (250GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 233GB (E:) HL-DT-ST DVDRAM GH22NS50 (ATAPI, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Hard Disk (C:) : 149GB (NTFS) @ Seagate ST3160318AS (160GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) SONGS (E:) : 233GB (NTFS) @ Seagate ST3250318AS (250GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) Optical Drive (D:) : N/A @ HL-DT-ST DVDRAM GH22NS50 (ATAPI, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS IXP SB600 SMBUS Controller LPC Hub Controller 2 : ASUS SB700 LPC host controller LPC Legacy Controller 1 : ITE IT8712F Audio Device : ASUS IXP SB600 High Definition Audio Controller Audio Codec : VIA 0397h Audio Device : ASUS RS880 Audio Device [Radeon HD 4200] Audio Codec : ATI (AMD) 791Ah Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : ASUS SB700 SATA Controller [IDE mode] Disk Controller : ASUS SB700 IDE USB Controller 1 : ASUS SB700 USB OHCI0 Controller USB Controller 2 : ASUS SB700 USB OHCI1 Controller USB Controller 3 : ASUS SB700 USB EHCI Controller USB Controller 4 : ASUS SB700 USB OHCI0 Controller USB Controller 5 : ASUS SB700 USB OHCI1 Controller USB Controller 6 : ASUS SB700 USB EHCI Controller USB Controller 7 : ASUS SB700 USB OHCI2 Controller FireWire/1394 Controller 1 : VIA 3403h FireWire/1394 Controller 2 : ASUS VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller SMBus/i2c Controller 1 : ATI SB600 SMBus SMBus/i2c Controller 2 : ATI AFS SMBus Network Services Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
If you are using a firewire interface or drive, your firewire controller is probably not compatible. You also have integrated graphics which can also be a problem(but you could disable it in BIOS and install a proper graphics card). I can't say for sure if the motherboard is compatible(with the newer AMD systems, its a total crapshoot). You also have 8mb cache drives and a larger cache might help in performance(but likely is not the major problem you are now dealing with). If you decide to add a video card, stay with 256 or 512 max(avoid the super-duper gaming cards with 1gb or more as they will hurt PT performance).
Something else I noticed is that after I did the general troubleshooting a nd optimizations stuff I no longer have my Synthogy Grand Pianos selections and IK Multimedia Total Workstation 2 selections in my multi channel plugin/ Instrument where you can select them to use with my midi controller?
pro tools not responding | tanweitan | Pro Tools TDM Systems (Mac) | 1 | 07-13-2012 06:35 AM |
Pro Tools (Not Responding) | XFM Production | Pro Tools TDM Systems (Mac) | 1 | 04-12-2011 08:38 AM |
Pro Tools LE 8.0.3 Not Responding!! | iamJayTech | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 06-16-2010 09:40 PM |
Pro Tools 7.3 (Not Responding) | Astar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-26-2007 04:26 PM |
Pro Tools not responding | soulsparkpro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-16-2005 08:07 PM |
