50fps session?
I have been asked to mix a documentary and apparently it will be edited and was shot using a 50fps frame rate. How do I deal with this in ProTools? I haven’t found that frame rate as an option. I have only worked at 25fps. They will be supplying an AAF.
Thanks
Scott Auckland New Zealand PT2022.5 Focusright RedNET 8Pre, RedNET R1 Z690 AERO D Workstation, I7 3.6GHz 12 core, 64GB RAM, Win10 Business 64bit |
Re: 50fps session?
Hi Scott,
You can't set the main counter or ruler to 50FPS but you can set the second ruler to 50FPS. You can then set your grids to 1/2 frames if you want a grid on every 50FPS frame. On a side note, if you will need to re-conform for picture changes during your sound post, EdiLoad can re-cut your session at 50FPS. Regards, Mark
Mark Franken, MPSE Dialogue editor/supervisor IMDb Creator of 'EDI' applications for sound post editors www.soundsinsync.com |
Re: 50fps session?
Thanks Mark.
I don't think I'll be needing a grid I just wanted to be sure that the session and the video file they supply play at the correct speed. Scott
Re: 50fps session?
Regards, Mark
Re: 50fps session?
Chears Mark.
Scott
Save session, close session, open session next day...clips have moved. | ptr22 | Pro Tools 12 | 8 | 02-18-2016 06:34 AM |
Pro Tools 9 crashes every time I open a new session or import session data | Ryan Butler | macOS | 14 | 03-23-2014 07:53 AM |
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 | doubtful guest | Pro Tools TDM Systems (Mac) | 1 | 02-06-2013 03:42 AM |
Vacuum patch gets shorter decay time at 96kHz session than 192kHz session | chrisdee | Virtual Instruments | 21 | 10-07-2011 10:02 AM |
End of Stream Reached - session broken - import session data does not work... | Sean Russell | Pro Tools TDM Systems (Mac) | 0 | 01-15-2010 04:56 PM |
