Sync I/O not recognized on Windows Pro Tools HD 7.4
For some reason my Pro tools HD 7.4 will give me the warning: Unable to establish communication with the Sync box when trying to enable sync options.
By Chosing Setup > Peripherals, and click the Syn-chronization tab and Click Enable SYNC I/O. However it does show me the correct timecode when opening the Sync Setup software in windows - pro tools - utilities. The sync I/O is connected via A custom Serial-to-COM cable. As stated in the Sync io guide. Any ideas? Thank you for your time, Steve Pittoors |
Re: Sync I/O not recognized on Windows Pro Tools HD 7.4
Steve,
When you want to use the SYNC with Pro Tools, you must connect the SYNC directly to the HD card. The Windows SYNC Setup Utility needs to be connected via the custom dsub (9-pin) to mini-din connectors (I could be getting the names of those connectors wrong.) When you use this software, you need to connect to the computers COM port. If you are running 7.4, almost all of the functionality of the Windows SYNC Setup Utility has been implemented in the Pro Tools Peripherals Dialog. The firmware can be updated using DigiTest. |
Elevenrack not recognized on Windows 7 | LarryWallwart | Windows | 0 | 11-29-2012 06:50 AM |
MBox2 - USB / Windows problem - USB device not recognized / DIM lights | galwanoskop | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-22-2012 12:56 AM |
projectmix not being recognized in windows vista anymore | wreckthisplace | Pro Tools M-Powered (Win) | 3 | 10-24-2008 06:09 PM |
Project Mix recognized but not sync with ProTools | MusicalWonder | Pro Tools M-Powered (Mac) | 2 | 08-01-2008 06:29 PM |
Mbox 2 wavedrivers not recognized by windows | Glichout | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-03-2007 05:21 PM |
