Cannot import videofile on Pro Tools 2019.5
Hi Everyone, I was looking for that around the web but I can't find anything about it, also, I contacted AVID SUPPORT, but no answer was given. Here's the problem.
I'm trying to import one video from a new client to pro tools 2019.5, installed on Mac Pro 5,1 + High Sierra (10.13.6) + SSD, I get the classic CODEC import error, I had reinstalled from scratch the operating system, without any success. But with Pro Tools 12.7.1 works like charm. I'd noticed that Pro Tools 12.8 has an updated Workspace file, and I don't know if that's related to the problem in some way. And I had tried to convert the video to other format like Apple Pro RES also without changes. Also I noticed that the video has a wired framerate 23,97fps not 24 as should be, but why older pro tools versions works fine? I was working with Pro Tools 2019.5 flawlessly until this event that force me to reinstall the OS and use a previous version of Pro Tools. Notice that this version isn't allowing me to import audio due to OS (I think) Any help would be appreciated. |
Re: Cannot import videofile on Pro Tools 2019.5
what type of video file is it? Avid has a new codec standard for video, DNxHD. You may need to convert your video file.
I’m not having any issues importing audio files.... but I do know there is an issue relating to QuickTime movie player and PT 2019.5 when it come to video. Maybe something to do with this.
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
It seems like I have to convert the file to DNxHR, but, why with pro tools 12.5.X works perfectly well? It's a wired framerate too 23,97fps, I work with audio so, not to much in the video settings and codecs. But converting to DNxHR works.
It's a quicktime H.264, all the others H.264 are working ok.
Are you sure its not h265 hvec? Pro tools is not compatible with it, thats what the latest iPhones record with. Just a thought.
Mac Pro 5,1 12 core 3.46ghz OS X 12.6.1 Opencore 0.8.6 Pro Tools Ultimate 2022.10 Mac Pro 2009 upgraded to 5,1 12 core 3.46ghz GPU RX6800XT, Samsung 970 EVO Plus pcie boot drive, Titan Ridge flashed for Mac. Midas M32r console. iPad Pro with Avid Control |
Help! Extracted Audio from imported Video DV-File is longer than the Videofile | chilln | macOS | 1 | 05-31-2011 08:13 AM |
Errormessege after changing videofile | iMartin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-05-2007 10:20 AM |
