Old 01-27-2018, 07:04 AM
chip_nelson chip_nelson is offline
Default 2018 | install plugin path?
I just installed 2018 | First. I also have PT 12.4 installed. What is the new plugin path so I can get my non avid plugins to work in 2018? Thoughts?
Old 01-27-2018, 07:39 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: 2018 | install plugin path?
Not all plugins work in Pro Tools | First. Only plugins purchased through the Avid Marketplace will work in PT | First. Although you may find some here and there that show up in First. The plugin path is the same for full PT.
http://avid.force.com/pkb/articles/e...ro-Tools-First
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 03-29-2018, 01:27 PM
Wire57 Wire57 is offline
It would be great to have an article telling us the install path for aax plugins in ProTools 2018.3. Maybe that would solve my question:
I now face trouble with another bundle: Black Shiny Wah, Black Op Distortion, Black Spring appear in my application manager, but when I try to use them in a PT session, the do not show up in the inserts list.
This time, I feel I could really need to use at least one of them relatively soon.
I have a case opened about this, they suggested a remote session, but I don't see how that yould happen.
How will the contact be established, by which application?
How will I know when?
Please, if anyone could update me either about the remote session, or about the not useable plugins, I'd be very thankful.
Old 03-29-2018, 01:34 PM
Are they in the same folder the other aax plugins are in? If properly installed they should be. Since you don't say what operating system you're using I can't give you the path you need to look at. See this page for the location(s): http://avid.force.com/pkb/articles/e...older-location
Jack
QAPLA!
Old 03-30-2018, 09:52 AM
Windows
C:\Program Files\Common Files\Avid\Audio\Plug-Ins should be right, thanks for that.
Yes, I find them there, all the three of them. So how come I do not see them in the inserts within my PT session?
In the screenshot, I had been trying to insert the "Black Spring Reverb" which does not appear.
Somehow I messed up the upload of that screenshot. Sorry. Just see the posting below, please.
Old 03-30-2018, 09:57 AM
Somehow I messed up the upload of that screenshot. Sorry. Here you go.
Old 03-30-2018, 10:52 AM
After seeing your screenshot I see your problem - the plugins you want to use are mono/multi-mono and not stereo; I'm assuming here that you're using a stereo instrument track. Look in the multi-mono menu and you should see then there.
Jack
QAPLA!
Old 03-30-2018, 01:47 PM
Thankx a lot, musicman691.
I'll have to write to the service people that the issue is solved. I should have known that before. I tested all the 3 plugins the way you advised me to, and - they are terrific, really what I was looking for.
So happy holidays for you!
Old 03-31-2018, 04:37 AM
Glad it worked. Have a happy & safe Easter as well!
Jack
QAPLA!
Lost HEAT in 2018 Install zeeman Pro Tools 2018 14 11-23-2019 12:35 PM
Focusrite Plugin Path Cutlerbri AAX Plug-ins 5 03-06-2017 08:36 AM
Plugin folder path Bfearr Windows 3 04-24-2016 08:07 AM
AAX Plugin Path [email protected] Pro Tools 12 4 01-20-2016 04:17 PM
Plugin Path on Mac, HEEEEEEEEEEEEEELP NEEEEDED!! MarkusB Virtual Instruments 5 10-07-2006 08:21 AM
