Old 10-07-2013, 09:09 PM
LukeHoward LukeHoward is offline
Default Video codec issue
Opening a session containing a 1920x1080 Apple ProRes 422 (HQ) video results in the error "This session contains media that is not supported possibly due to a missing CODEC".
It opens fine in 11. Video Engine is enabled.
Ideas?
https://lukehoward.com/
Old 10-08-2013, 10:38 AM
Rikk Rikk is offline
Default Re: Video codec issue
Just had this same issue. PT11 would not open or import video. PT10 did fine.
It came down to the file name. It had "/" and "#" in it. Replaced those with underscore and it worked.
Old 10-11-2013, 05:30 AM
Hmm. Didn't work for me, renamed it to just alpha characters with no spaces or anything. Back to 10 for me.
Old 10-18-2013, 04:10 PM
jb_trm jb_trm is offline
I'm having the same issue, except that this is with a video that PT 11 most of the time has no problem playing back in the project. About 1 out of 4 times loading the PT 11 project I see the error "This session contains media that is not supported possibly due to a missing CODEC."
The first warning sign is when PT opens the project and a warning is shown that the video engine has had an issue and needs to be restarted.
I'd say that this is a bug that needs to be further researched.
Old 10-18-2013, 06:35 PM
studioj11 studioj11 is offline
Open activity monitor and find the "Avid Video Engine" Process. Select quit process and choose force quit. Pro tools will give you an error and click ok. video engine will relaunch and video should import properly now. I discovered this workaround recently and it seems to work every time. Also gets around the play pause bug and is a little quicker than restarting pro tools or disabling and re enabling the video engine from within PT.
Old 09-19-2014, 04:49 PM
mBox mBox is offline
Originally Posted by studioj11 View Post
Open activity monitor and find the "Avid Video Engine" Process. Select quit process and choose force quit. Pro tools will give you an error and click ok. video engine will relaunch and video should import properly now...
Just ran into this issue with AMA RED R3D files. The odd part is out of the 4 clips the last one shows up even with the error.
I tried your tip and still no go with same odd results.
I could Transcode all the videos (I only did the audio to see if AMA works) but man its a full feature length film (editorial at DNxHD36 HD).
Its been a year after the prev post, has there been any changes?
Im on Avid MC 7.0.4 and Pro Tools 11.1.3 running on Mac Pro Cheese Grater 10.9.4.
Old 09-20-2014, 12:31 AM
Ok this is weird.
I grabbed an AAF exported from Resolve 11 just to see if it would choke Pro Tools since the AAF contained 134 RED R3D clips converted to MXF.
They seem to work in Pro Tools from Import Session > AAF.
Sadly the audio didnt come in
Old 09-22-2014, 12:39 PM
FajitaTone FajitaTone is offline
embedded media? PT has never liked embedded media AFAIK.
Ray Trujillo
Freelance Audio Engineer
Old 09-27-2014, 09:52 AM
Danny Caccavo Danny Caccavo is offline
One other thing to check - if it has an AAC soundtrack, open the video in QT7 player pro and disable the soundtrack.
HTML code is On
Best video codec for 11? Kasper Post - Surround - Video 90 01-22-2014 10:46 PM
Best video codec to use with PT11 Intransit Pro Tools 11 2 01-13-2014 11:56 PM
PAL video codec for PT HD 8.1 on a PPC Mac Larold Post - Surround - Video 8 09-24-2011 10:05 AM
VC-1 video codec lxaudio Pro Tools TDM Systems (Mac) 5 04-06-2009 02:23 PM
QT codec issue Karl Engel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-11-2009 02:38 PM
