Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 01-18-2019, 03:35 AM
kathpollard kathpollard is offline
Default ffwd & rwd ‘lock’
Anyone had flashing rwd&ffwd at the same time? Running an HDX 2 rig on satellite with 5 other rigs. Problem occurs regardless of satellite connection status. System still runs in this state but prevents transport working on attached S6. How to clear problem without rebooting?
Old 01-19-2019, 07:25 AM
EddieJones's Avatar
Default Re: ffwd & rwd ‘lock’
You are not going into jog or shuttle are you ?
Old 01-23-2019, 09:21 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Does it prevent playback, flash, and then stop? I used to have that happen and the "fix" was to change the buffer size then play. Then, change it back, and carry on.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Lock up with USD DENNIS MK Pro Tools TDM Systems (Mac) 2 07-22-2002 07:51 AM
ptf LOCK-UP mjc1124 Digidesign Hardware & Software 0 10-21-2001 04:24 PM
To Lock or Not....NOT stunningfuture 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-03-2001 12:54 AM
pt won't let me lock after 23:22:00 zeeman Pro Tools TDM Systems (Mac) 6 05-02-2001 06:38 AM
lock ups on 5.1 boutwell Pro Tools TDM Systems (Mac) 14 03-09-2001 06:16 PM
