Old 09-28-2016, 12:54 PM
Basstian Basstian is offline
Default Fine breakpoint adjustment change in 12.6 = Showstopper
Did not update yet, but after reading the release notes I guess I am stuck with 12.5.2 for now.
Additional Editing Improvements
Fine breakpoint adjustment now requires Shift+Command (Mac) or Shift+Control (Windows) keys and adjustment is constrained vertically.
How should that make an improvement? I use the fine adjustment (holding down the commend key) thousands of times a day while editing dialog adjusting the clip gain. Without the fine "commend" key the range is always too big and you have to readjust too often.
Adding another key will be very uncomfortable, but you might get used to it.
But constraining the adjustment vertically renders it completely useless for dialog work, because a "free repositioning" of the breakpoint is one of the keyfeatures with clip gain.
this is a real showstopper. I could not see how this could be an improvement and who might want this kind of behaviour and additional key.
Old 09-28-2016, 01:01 PM
Pete Gates Pete Gates is offline
Default Re: Fine Adjustment 12.6 = Showstopper
Still works the same (as in same as it always used to work) in setting clip gain - just tried it.
I almost never use the mouse for clip gain, tend to use Ctrl+Shift+Up/Down arrow.
Pete
Old 09-28-2016, 01:02 PM
Pete
Do you speak of clip gain breakpoints?
I nearly never use the "general" clip gain, but a lot of individual points on the clip gain line of a clip. And I understand the release note in that way, that editing breakpoint just does not work like before anymore.
Old 09-28-2016, 01:04 PM
connor@@vid's Avatar
connor@@vid connor@@vid is offline
Pete
Old 09-28-2016, 01:06 PM
Old 09-28-2016, 01:18 PM
Ah I see, just tried it and you DO have to hold shift too now - sorry to be the bearer of irritating news!
Pete
Old 09-28-2016, 01:20 PM
Shan's Avatar
Shan Shan is offline
+1. Pro Tools has always been known for it's unified editing experience throughout the entire program. That's what made it Pro Tools back in the day. This just makes things very messy, and doesn't just impact post production. Many of the controls throughout the UI now have two fine control commands now. Why? Who at Avid signed off on this and thought it was a good thing?
I guess this was another top 10 Idea Scale request.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 09-28-2016, 01:35 PM
Pete
and if you hold shift + command it is locked vertically?
Old 09-28-2016, 01:38 PM
Yes
Old 09-28-2016, 01:45 PM
ok. this makes 12.6 useless. only vertical fine adjustment. and different modifierers tor fine adjustment in different tasks
who is deciding stuff like that?
Fine Fader Adjustment On iPad? producedbyriot Avid S1, S3, Dock and Control App 4 09-10-2016 01:00 PM
Fine Adjustment on AAX seems to be Broken? Neil Pickles AAX Plug-ins 4 06-07-2013 01:39 PM
fine adjustment of breakpoints not working levelaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-03-2010 06:42 AM
Fine volume adjustment gbours Pro Tools TDM Systems (Mac) 3 05-02-2006 07:23 PM
Strip Silence and Fine Adjustment... Still a bug? SimpleNatureSpirit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-21-2004 11:22 PM
