ProFire 2626 + Dangerous D-Box: Correct Routing for Summing???
Hi everyone
Been trying to set this up correctly. Anyone out there figure out how to configure everything in the control panel as well as in ProTools to use the analog summing of the D-Box with the ProFire 2626? For extra fun, I do have the API A2D's direct converter inputs to play with in case that might help. But for now, following everything I have found online, I simply cannot figure out the correct configuration for this setup. And I am in the middle of a busy mix week. So, I thought I would throw it out to the interwebs and see what comes back! Thanks russell wolff
www.russellwolff.com I produce things @ www.krazypopstudio.com Endorsements and affiliations: MikTek Microphones, AVID, Klotz Cables, CAD Headphones, ToonTrack, Parker Guitars, Taylor Guitars, Steven Slate, Seymour Duncan Pickups, D'Addario, Bugera; Dangerous Music, Digidesign, Focusrite, IK Multimedia, Altiverb, Focal Monitors, and SurgeX. Pro Tools 12.4 HD, MBP Quad-core 2.5Ghz i7, 16GB RAM, UAD-2. Interfaces: UA Apollo 8 |
Re: ProFire 2626 + Dangerous D-Box: Correct Routing for Summing???
You know. I never returned to this thread. Sorry.
So, it finally worked perfectly. Everything was routed correctly all along. Here was the issue, the master volume knob on the 2626 was all the way down. Since I use the D-Box to monitor my mixes, that never occurred to me. Once it was turned up, all 8 outputs worked perfectly. So, a simple fix
You can change the internal settings of your pro fire so selected outputs bypass the master volume control.
I do this for my outputs running to outboard gear so I know the same level is going to the outboard. Important if jumping between mixes. Also, you can leave two outputs routed through the master volume for your monitors.
- Macbook Pro 2.5Ghz, 4gb RAM, 320Gb HD @ 7200RPM - 2 x Profire 2626 - PT8.0.1 M-powered - Yamaha HS80M - Axiom Pro 49 - 500GB Sarotech Hardbox external HDD plugged through express card, FW800 - Waves Gold bundle, L3-16, Eddie Kramer - 2 x Coles 4038, Royer 121, 2 x Shinybox MXL, 4 x SM57, 3 x SM58, AKG D112, SM81, Shure 16A, sE 2000, 3 x Audix D2 |
Upgraded to PT10 And Now Profire 2626 Routing Issues | swag74 | Pro Tools 10 | 2 | 12-16-2013 01:36 PM |
Profire 2626 routing problems | duanebonney | Pro Tools 10 | 13 | 06-08-2012 01:15 AM |
Question to Dangerous summing box owners? | Eduardo Apolonia | General Discussion | 8 | 04-19-2012 03:25 PM |
Is the Profire 2626 more stable than Profire Lightbridge? (PT8 or snow leopard?) | tomv-k | Pro Tools M-Powered (Mac) | 5 | 03-09-2012 02:45 PM |
Profire 2626 routing issue | boabyd23 | Pro Tools M-Powered (Mac) | 0 | 05-03-2010 02:27 AM |
