Re: Mid Side Miking Technique
I never heard of a criteria called "serile stereo". Also what does "boring" mean in terms of stereo width, depth of field, localization capabilities. please specify. frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Spaced mikes give you time differences as well as amplitude differences in each channel. Coincident techniques do not. ORTF gives you time differences that approximate what happens when you hear using two ears spaced about the width of the human head. For humans, this sort of makes sense - why not try to capture time differences between channels that the listener's ear would also hear? Dummy head recordings take this a step further and use the refractive properties of the ear's pinnae to color the signal going into the two mikes. I have heard some very realistic sounding recordings done with dummy heads. Does anyone remember Holophonics? It was a particularly good dummy head that got used heavily on Pink Floyd's The Wall for a lot of the SFX and I thought it was very realistic sounding. At an AES long ago, they gave out a test disc of someone pretending to cut hair around the dummy head. It was possible to locate the shears as they pretended to cut not only left and right, but up and down and front and back due to the pinnae refraction. Cool demo... -monte- |
Anyone know of a company making a dual opposing element condenser that has a separate output for each diaphram? This would let us decide if we want Fiqure 8, omni or Cardiod later. . . as well as provide a version of stereo that mono sums to Omni. Anyone see a mic like this or try anything like this?
...for system configuration info see my profile (Click on member name) |
ORTF seems to make much more sense in terms of realism. However there are times when it just is not practical.
I am getting ready to mix location sound for a feature and my boom op will be using a M/S mic primarily to gather ambience for some EXT MOS scenes. The mic will have to be on a boom and there is no practical way to do ORTF. There are scenes where I will use ORTF technique. Thanks Monte. |
#17
Monte,
thanks for explaining the term sterile and boring to me. I learn every day. I was simply wondering what you mean speciffically when you talk about sterile sounding stereo. What would be the oposite? Dirty organic stereo? Would that information would be any different from describing stereo as "silky" "fractal" "extremely LA" or "more spicy" ? Hm....not sure. frank.
#18
Here is another post with more info on this topic: MS Techniques
#19
[QUOTE]
Monte, thanks for explaining the term sterile and boring to me. I learn every day. {/quote} I know you're from a different country and perhaps English isn't your native language, so I'm pleased that you stayed with me so long. I'm not trying to be cryptic, but it might happen now and then by accident.... Quote:
I experimented with spaced mike tchniques such as ORTF, and found that the resulting recordings had a lot more depth and detail than my previous recordings, so I decided to abandon coincident techniques. Yes, I think mono compatibility is a worthwhile thing, but at the same time, spaced mikes can give such a larger sense of space and dimension, so I feel that they're worth using. So, to answer your direct question, I think that coincident techniques rob the listener of information that could have been recorded by a spaced mike technique. I know that not every engineer will hear things the way I do or strive for results that I feel are worthwhile, so I don't want to say that my way is the only way. But, having used all of these methods for some time, I find I'm most happy with spaced mike techniues and not coincident techniques. Regards, -monte- |
#20
[QUOTE]
[QUOTE] Monte, thanks for explaining the term sterile and boring to me. I learn every day. {/quote} I know you're from a different country and perhaps English isn't your native language, so I'm pleased that you stayed with me so long. I'm not trying to be cryptic, but it might happen now and then by accident.... [QUOTE] now this is funny...the world of text communication is full of misunderstandings
Side-by-side configuration error | peter5992 | Windows | 15 | 05-18-2012 08:30 PM |
can I use the Mbox2 side to side to an Omega Lexicon?? | nastyartproduction | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-23-2010 06:46 PM |
New: Lopes Stereo Miking Technique | Alécio Costa | Pro Tools TDM Systems (Mac) | 9 | 02-14-2009 09:12 AM |
Digi,Side by Side errors in event viewer with PT's HD 7.4? | x9blade | Pro Tools TDM Systems (Win) | 8 | 12-15-2007 11:19 AM |
Mid-Side Mic'ing (not the technique, the mic) | Ryan Young | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-26-2006 03:04 AM |
