Old 11-01-2011, 12:12 PM
digidesigner digidesigner is offline
Default Avid Virtual Instruments 10 installer, no XPand sounds?
Just installed this package for Pro Tools 10 and got an error of missing XPand file. Sure enough when opening XPand there is no sounds. Is it me or is the installer bad?
EDIT: Will try to download again, the ZIP file did not extract correctly and gave error on xpand big file
Old 10-12-2012, 12:21 PM
lvly5t lvly5t is offline
Default Re: Avid Virtual Instruments 10 installer, no XPand sounds?
There is a drop down box on xpand that will let you look through you files. find the folders that came in the VI download and select xpand's file. it's like xpand.big i think. I had this same issue. It's all there you just need to open it through xpand if that makes sense. this is a one time problem btw you wont need to go through your files every time. hope that helps
Avid Virtual Instruments 10.3 Installer issue bower.steven Virtual Instruments 2 08-20-2013 09:31 AM
Where did the Virtual Instruments Mac installer boxman macOS 3 05-13-2013 10:06 PM
Avid Virtual Instruments 10.3 Installer (Mac) RokVox macOS 3 10-30-2012 04:40 PM
Can't download Avid Virtual Instruments 10.3 Installer (Mac) [solved] quantise macOS 2 10-05-2012 03:37 AM
Avid Virtual Instruments 10.3 Installer Becharax Windows 3 09-18-2012 07:21 AM
