Old 12-05-2010, 05:03 AM
progtools progtools is offline
Default Need a sound replacer to use with addictive drums
I am currently mixing a track which i didn't record and those who did made a real hash of the Kick drum mic'ing so i need to do some sound replacing on it using addictive drums. I am on a bit of a budget but any recommendations of sound replacers that are affordable and work well enough would be much appreciated.
Old 12-05-2010, 05:39 AM
Stig Eliassen's Avatar
Default Re: Need a sound replacer to use with addictive drums
If it's only one track I'd do it manually by pasting a MIDI note at every kick transient.
Old 12-05-2010, 06:34 AM
Tim R. Tim R. is offline
Yeah, It can go pretty quickly if you use "Tab to transient".
Old 12-05-2010, 05:13 PM
nst7 nst7 is offline
I have a license for Digidesign Soundreplacer I could sell fairly cheap.
Contact: [email protected].
Old 12-06-2010, 11:45 AM
BaileyBass BaileyBass is offline
Stick with PTL and Tim R's suggestion. At least you know that method is accurate. sb
Old 12-11-2010, 10:09 AM
emluper emluper is offline
Just make sure you listen closely to the track. You might have to massage a couple of notes to get the kick to "feel" right.
Addictive Drums RTAS instrument plugin much softer when drums are "individualized" jglunt2112 RTAS & TDM Plug-ins 7 12-05-2013 06:54 PM
Addictive Drums - No Sound piwacquet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-11-2011 09:17 AM
Addictive Drums Julia B The Drum Room 0 12-16-2010 01:50 PM
addictive drums, drums replacement ericlees Tips & Tricks 2 09-28-2010 10:58 PM
Addictive Drums Stickman7 The Drum Room 1 10-11-2009 07:15 PM
