Old 01-09-2010, 04:21 PM
musiclovin musiclovin is offline
Default Having a problem in Pro Tools when recording vocals
I'm having a problem that I can't figure out what is wrong.
When I record vocals in Pro Tools it "looks" like that it is being recording very loud, to the point of peaking, the thing is I could barely hear the vocals coming out of my headphones.
While ago, I when I was playing back the vocals in Pro Tools I could hear a static very loud sounds when the vocals were playing back.
I rebooted my computer, as of now I don't hear "static sounds" but I still can barely hear the vocals but it looks like that I recorded the vocals very loud.
Thanks,
Old 01-09-2010, 04:28 PM
mkosacek mkosacek is offline
Default Re: Having a problem in Pro Tools when recording vocals
clipping the meters or just the waveform looks big? there's an adjustment for the waveform size up on the top near the transport (icon of waveform with arrows on top/bottom). maybe it got adjusted...
Mike
Pro Tools 2022.9
UAD Apollo 16 (v10.1)
Dell XPS 8940 (i5-11400)
Win10
www.studiodrumtracks.com
www.doubledogrecording.com
Old 01-09-2010, 04:30 PM
The waveform looks very big, the thing is I could barely hear the vocals. Meter looks OK.
Old 01-09-2010, 04:34 PM
pianosound pianosound is offline
If it is just wave forms, you can hold shift/alt,, and use scroll wheel to make waves larger/smaller.
Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 |
Old 01-09-2010, 04:38 PM
Maybe I didn't say what my problem I'm having correct.
The wave form is showing big, but when I record vocals, I can't hear them very well.
Wave form is very big, but when vocals are being recorded normally the playback is very low.
Old 01-09-2010, 04:44 PM
audiogeekzine audiogeekzine is offline
m-box mix knob?
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 01-09-2010, 04:49 PM
JonnyGinese JonnyGinese is offline
When you are recording.. how much signal is going into the METER? th wave form can be manipulated to LOOK big but not actually be high signal. I'm my experience its usually best to have your signal Tapping the yellow of your meter...
Do you have any plugins on the channel? if you have a compressor? you could be compressing it but not compensating with the output.
-AIM: RS Recordings -Skype: RSRecords
| Pro Tools 8 Native | Windows 7 64-bit| Q6600 @ 3.0ghz | 8GBs RAM | Digi002r |
Studio Site: Red Sneaker Records
Old 01-09-2010, 04:56 PM
It is in the yellow when recording the vocals.
Nope, None.
However, when I'm recording the vocals, through my headphones I could barely hear myself when recording the vocals.
Old 01-09-2010, 05:24 PM
To add...to here myself I have to turn the volume strip to +12.0.
Old 01-09-2010, 05:27 PM
what interface do you have?
Static Problem when recording vocals Filmmaker123 macOS 0 10-20-2012 07:33 AM
Problem With Recording Vocals in Pro Tools Visceral 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-09-2009 04:44 AM
Problem with recording vocals in Pro Tools 8 Abdul Aziz General Discussion 2 02-27-2009 05:00 AM
Problem with recording vocals in Pro Tools 8 Abdul Aziz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-02-2009 10:05 PM
Problem recording vocals!!!Help!!!Delay!! dmt2828 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-11-2007 12:14 PM
