Old 11-27-2007, 06:57 PM
x9blade x9blade is offline
Default Digi,Side by Side errors in event viewer with PT\'s HD 7.4?
happen to look in my event viewer under system, after installing 7.4 and i noticed a string of side by side errors. is this something to worry about? here is a list i copied and pasted, this is only 3 out 9 but, you get the idea. they seem to be pointing to D control
Event Type: Error
Event Source: SideBySide
Event Category: None
Event ID: 59
Date: 11/27/2007
Time: 9:32:46 AM
User: N/A
Computer: QUADZILLA
Description:
Generate Activation Context failed for C:\Program Files\Common Files\Digidesign\DAE\Controllers\D-Control_Resource804.dll. Reference error message: The operation completed successfully.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Event Type: Error
Event ID: 59
Date: 11/27/2007
Time: 9:32:46 AM
User: N/A
Computer: QUADZILLA
Description:
Resolve Partial Assembly failed for Microsoft.VC80.DebugCRT. Reference error message: The referenced assembly is not installed on your system.
Event Type: Error
Event ID: 59
Date: 11/27/2007
Time: 9:32:46 AM
User: N/A
Computer: QUADZILLA
Description:
Generate Activation Context failed for C:\Program Files\Common Files\Digidesign\DAE\Controllers\D-Control_Resource412.dll. Reference error message: The operation completed successfully.
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
Old 12-10-2007, 11:44 AM
Default Re: Digi,Side by Side errors in event viewer with PT\'s HD 7.4?
curious if someone else can confirm this? digi?
Old 12-10-2007, 02:23 PM
Brandonx1 Brandonx1 is offline
Hi x9blade,
On my rig I get the same strin of side by side errors everytime I start/boot pro tools. Is that what your getting? I'm not having any problems to report.
Best,
Brandon
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 12-10-2007, 05:31 PM
hello brandonx1.yes, that is what i'm getting. everytime i launch just as you. no problems except seeing errors in my system viewer.just don't like the feeling of having errors everytime i start pt's.
thanks for confirming.maybe digi will chime in and explain
Old 12-12-2007, 09:56 PM
Bharath's Avatar
Bharath Bharath is offline
Do you have a D-Control by any chance?
I don't think it is a serious issue, but, we will look into it.
:: Bharath
Pro Tools Software Team
Old 12-13-2007, 07:42 AM
finally, thanks for responding Bharath. no i do not have a d control. i use a command 8.everytime protools launches i get these errors. so far i do not think it is causing any problems.was just curious
Old 12-14-2007, 08:09 AM
No D-control here either. Command 8 as well.
Best,
Brandon
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 12-15-2007, 10:02 AM
Bharath's Avatar
Don't worry about the event log error message. I have a note for myself to fix it for a future update.
:: Bharath
Old 12-15-2007, 11:19 AM
thanks for the responce
PT10 and PT11 side by side over HD3 s9dd Windows 8 02-11-2014 08:22 PM
Side-by-side configuration error peter5992 Windows 15 05-18-2012 08:30 PM
can I use the Mbox2 side to side to an Omega Lexicon?? nastyartproduction 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-23-2010 06:46 PM
side by side error message johncm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-17-2009 02:43 PM
MIDI Event List overflows on the left side of PT's window Fastudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-13-2008 03:08 PM
